Question about RCA P52926 52" Rear Projection Television
Triplicate picture. Our RCA - R56WH78 made a sizzling noise and the picture became wavy. Now when you turn the TV on the picture is in triplicate. The TV is less than 23 months old, please help!
The alighnment of the colours will not come together after a T.V. repair man fixed my T.V. (NOT) The picture has the red out of line and the blue fuzzy. What is the issue???? We live out in the boonies and it takes a two hour drive for someone not to fix it. I do not wish to spend another $400.00 on this. Please help me my husband is desperate and I am starting to look really good to him.
Posted on Feb 06, 2009
I had the same problem.trawled the net and tried this advice ....thump the thing around top and sides. it worked for me, it was something to do with bad connections in a soldered joint.problem will probably get worse though
Posted on Jan 24, 2009
I have a sony color rear videoprojector tv model kp-57ws500 that when i turn it on its blurry and video or dvd word is red blue yellow almost like in triplicate. after about 45 min. it clears up and works...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 25, 2011 | Sony KP-57WS500 57" Rear Projection...
52" projection, colors have seperated making images in triplicate
Go to the main menu on your TV and scroll down to picture then press select. Then scroll down to convergence and press select again. Next follow the on screen instruction on how to perform a static convergence on your set. If this doesnt solve your problems check all capacitors in the convergence section of your TV. If problems persist replace both convergence chips.
Aug 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA d52w23 shows pictures in triplicate:blue green and red.
There are several things that can cause this. There is a "light pipe" that connects from the lamp to the color wheel. If the mirrors inside have become dirty, broken, or have shifted it will cause the picture to do this. Also the color wheel itslef could be dirty or worn out. And the final culprit could be the light engine itself. You can have any in home TV tech test these out for you.
Jan 06, 2009 | RCA D52W23 52" HDTV CRT TV
How to repair a samsung rear projection tv
your power supply is getting weak
Aug 25, 2008 | Televison & Video
Rca hd52w67 w/irc222 chassis
if in setup the convergence option is missing then more than likely a special fuse fl231 has blown... this is caused by bad solder connections on the part known as the flyback... if you can solder and get the fuse then this could be a simple fix
Jun 01, 2008 | RCA HD52W59 HDTV Projection Television
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
Skewed picture
Is it a projection? DLP? LCD? etc... depending on the type the suspicion i have is it is out of focus.  The symptom of writing triplicate comes from the thing being out of wack.. a tech needs to fix it.  all this is assuming ;you have a projection tv of some sort.
Mar 02, 2008 | Samsung PCL545R 54" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
