Question about Vacuums
I can't take lid off steam cleaner!
  • 91 Answers
Need more information like make and model of steam cleaner
Posted on Jan 14, 2013
3 Suggested Answers
TEVA Guru
  • 65 Answers
SOURCE: Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Posted on Sep 10, 2009
small6363
  • 18394 Answers
SOURCE: I CAN'T OPEN THE LID TO FILL IT WITH WATER
press down hard and turn antyclockwise
Posted on Dec 31, 2012
My Shark hand held steam cleaner sc 505 is not building up pressure, steam is leaking from lid
Throw it out, get a hoover floormate, best machine I ever had. My Shark steam/vac now resides at the dump after steam clogging problems and not being able to remove the hose to blow it clear.
Mar 17, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam cleaner sc 505
you need a new seal to put on the lid
Mar 17, 2014 | Vacuums
Dec 31, 2012 | Vacuums
Not sucking up water
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN..
Oct 14, 2012 | Hoover Steam Vac Carpet Cleaner Spinscrub...
How does the red thing fit back into water tank
if that doesn't come up, type in bissell water tank into google & then select 'images' from the results. The large rectangular block of plastic is inside the tank between the clear plastic tabs. The long red plastic stick with the 2 tabs goes on top of the lid
Dec 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover steam cleaner I
E-mail me for the parts manual (firehead@rogers.com)then do the following.
Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Feb 01, 2009 | Hoover F5835900 Upright Steam Vacuum
Setting up for apolstery cleaning
Hoover Steam Vac F5853-900 Series 17.9
Remove the tank front panel by sliding it straight up. Replace panel with converter (located on end of hose, end is shaped like front panel that you slide out.Before connecting tube to cleaner, make sure black tabs are extended by pulling tan collar roward tube.Open door on hood labeled "Stair/Upholstery Cleaning Connection" Press round solution tube connector onto round projection inside door. Press connecator collar down firmly to ensure that it is fully connected.
When the solution tube is connected to the deep cleaner, the nozzle brushes will automatically be turned off and will not rotate when the deep cleaner is turned on even if the speed selector is in the HI oar LO position. For full suction, it is important that the recovery tank lid is properly secured before cleaning.The tank lid is replaced in a hinge-like manner. Position front of lid under tabs on front of tank. Rotate lid down onto tank. Make sure lid is secure on all sides before cleaning.Hope this helps.
Good Luck
Nov 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steam vac
OKay! I've figured it out! After making sure I had the cleaning solution container connected properly, the "lint filter" thingy clear, the attachment plug thingy unplugged, the filter in it's proper position, (about a cm down from the seal), and the seal on the filter was all good, etc etc etc, the brushes in properly...I was about to drive over this steam cleaner with my car!
After taking a break and going back to it, I discovered that I didn't have the lid to my dirty water tank (or air tank, as I was starting to call it) properly closed. There are two lips that you have to make sure the lid "hinges" from, and THEN snap the lid shut. This made a seal that allowed this steam cleaner to **** up all kinds of gooey gunk from my carpets! The brushes work, the suction works, it's a FABULOUS machine! It doesn't get any louder when it's sucking up water, either.
All this AND I had the instructions! Go figure!
Jul 12, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam scrub steam vac
The recovery tank also has a clear plastic piece in the front that is suppose to be snapped into place to make sure its in place pull on it in the direction of the handle of the steam cleaner if it snaps then that was the problem it got out of place
Sep 09, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
78 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
