How to uninstall IDM
Windows 7
  • 27,725 Answers
Force Uninstall Software b> You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have disable it in toolbar extensions
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Hope this helps. Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
Posted on Jan 15, 2013
What is the code of idm for pc.
here the info... this I had to research for you.
1. First Uninstall any previous version of IDM
2. Restart your PC
3. Go to my IDM rar archive and extract content from it. You may need WinRAR/7z or any other similar software installed to open the file.
4. Go to Patch and Crack folder and click "Unregister.reg" key file.
5. Now install IDM with the setup file- file name "IDM_Setup_6.12_b15_Full.exe"
6. During install you will get many pop up window - just close all the window
7. Now exit Exit IDM from the icon tray from bottom right corner of the desktop
?ui=2&ik=dc0e450f3b&view=att&th=139a923b836ebbb6&attid=0.1.1&disp=emb&zw&atsh=1
8. Now again go to Patch and crack folder and copy the -"IDMan.exe" file and paste and replace it in - C:\Program Files\Internet Download Manager i.e [C drive> Program File> Internet download manager folder.]
9. Now determine your operating system architecture weather it is 32 bit or 64 bit.
To Know the architecture go to run Press [Windows key+R]
?ui=2&ik=dc0e450f3b&view=att&th=139a923b836ebbb6&attid=0.1.2&disp=emb&zw&atsh=1+ R
10. Type CMD and press Enter
11. A black window will open. Type the following and press enter
echo %PROCESSOR_ARCHITECTURE%
12. If it shows x86 then your PC is 32 bit or if it shows x64 then your pc is 64 bit
13. Now that you know your Operating system Bit rate go to Patch & Crack folder and dubble click "RegKey Windows 32bit" if your pc is x86 or dubble click "RegKey Windows 64bit" if your pc is x64. Do not Dubble click both of them.
14. Now run Internet Download Manager from Start Manu>All program.
There is also a installation instruction given inside the rar file. You may need WinRAR/7z or any other similar software installed to open the file.
N:B- Never update IDM coz update will damage your registration
Note: If you get the message "Fake serial number" after installing, uninstall IDM, run "Unregister.IDM" to remove any previous serial from registry, reboot PC, install IDM again, use the crack & regfile to activate it.
!Optional! You can also try adding the following to your hosts file.
C:\Windows\System32\drivers\etc hosts - Then Right click & open with notepad
(You will need to take ownership of the hosts file and make sure you have all permissions set)
127.0.0.1 www.internetdownloadmanager.com
127.0.0.1 internetdownloadmanager.com
Tony
Feb 09, 2013 | Computers & Internet
Every time i open up IDM it appear IDM has stopped working. I even try reinstall clean version and format my desktop then try install, it still appear IDM has stopped working.
first of all please Completely uninstall the IDM using the Revo Uninstaller Software..... then install the old version of IDM.......... then update the Idm... it will surely works
Aug 30, 2012 | Computers & Internet
I CAN'T DOWNLOAD ANYTHING DUE TO THAT POP-UP MESSAGE THAT KEEPS COMING THAT IDM IS EXITING AND I AM FED UP I WANT IT TO EXIT MY SYSTEM FOREVER.
try to go to your uninstaller in control panel and try to uninstall IDM, then restart your pc, try again to download something and it should work now. It only means that your idm got an error, re-installing idm will work after uninstalling it and restarting the pc.
Apr 19, 2011 | Computers & Internet
"idm has been registered with
The problem seems to be with the serial key you provided for IDM. IDM blocks every pirated serial key and it is the reason you are getting the above message.
The solution this problem has been given by techforum4u.com
The solution for this problem is not easily available and the only step the user left with is uninstalling the software completely. Even after several installation and uninstallation the problem exists unless you format your computer.If you want a permanent and exact solution for this problem follow these steps:-
1. Exit IDM from the taskbar before entering the serial.
2. Disconnect active connections to the internet.
3. Then go to the directory C:\Windows\system32\drivers\etc and locate the file 'hosts'
4. Open the "hosts" file with "notepad".
5. on the last line enter the following address as shown and save.
6. Now, again enter the "fake serial" and wait for few seconds.
7. your IDM is registered again.
8. No wonder you would be facing this problem again but without panic use a "new fake key" ( this time steps 3,4 and 5 are not required, the only thing required is "a keygen" for generating a new key. For IDM 5.14 Dr.Carbon Keygen is used ).
Mar 22, 2011 | Computers & Internet
Sir i had installed idm 6.4.1.6 trial version for 30 days. now iam unable to download anything with it.it display the window showing that idm was is installed with fake seriel number or idm was blocked
whenever you installed any pirated software never update it because the website block your idm and you bacome unable to download anything from the websites ...so u can uninstalled ur idm and then again installed after restarting ur system...@@@@@@
Mar 18, 2011 | Computers & Internet
Serial key for idm not having
Internet Download Manager Registration serial nomber 6.12
May 13, 2010 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
