Question about Lands Phones
Vtech cs6629-2 static and echo when used - Lands Phones
Dial tone sounds static and voice echos. How to fix?
Hi anonymous, ;)
You can try to reset the phone by disconecting the battery..
Rconnect and place it on the receiving unit to reconnect it to the network
Apr 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
Www uniden com au
Hi, Irene Garla!
When did you start experiencing this type of issue from your cordless phone? Usually you get echoes of your own voice when your base phone is on speaker mode. Either you get an echo or a feedback from the speakers from both units when you're on a call.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Nov 05, 2013 | Vtech 5.8 Ghz Handset Cordless Phone...
When i move the cord on my turtle beach x1 it gives me static and the mic echos when people talk. any ideas?
I found this on the Turtle Beach website: _________________________________________
If you or other players hear echoes in Live Chat:
Does it happen if you use the Microsoft communicator? Mute the microphone on your headset. Does the echoing stop? In the Xbox Dashboard > Settings > Live, set the voice to Play Through Both and unplug the talkback-controller cable. Does the echoing stop?
Echoing can sometimes be caused by high latency ("lag") on your internet connection. This may come and go depending on how much bandwidth is being used in your area.
If your talkback-controller cable's plug gets dirty, this can also cause echoing or static. Also check the input jack on the controller and make sure no foreign objects are in there.
Read these links for more advice:
Echoing can be caused by "a poor connection between the headset and the controller." http://support.microsoft.com/kb/912493 "The most likely cause is either a plug that isn't pushed all the way in, or gunk on the plug." http://xboxelle.spaces.live.com/Blog/cns!1pUP4M-J1d781v7Ac0Ta8FDw!158.entry "If you hear echo, then... someone in the chat session... needs to clean off their metal headset plug." http://majornelson.com/archive/2005/12/25/get-rid-of-voice-echo.aspx
Nov 30, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Echo while talking to some other phones
U see echoing isnt d problm f the phone... It`s the pbm of d service providers (yr network)....dnt worry they usually get repaired when the correspondn frequencies are altered.....
Apr 12, 2009 | Vtech Cordless 6041 Phone
Buzzing
you need to ring up ur service prover you they can fix the line for you its not the phone
Mar 02, 2009 | Vtech 5.8GHz Analog Cordless Phone
Echo suppression
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 08, 2008 | Logitech Quickcam Ultra Vision Webcam
Setup answer machine
My phone echos when it plays the answering machine with my recording, how do I stop it from echoing?It is a vtech 5.8ghz phone.
Sep 06, 2008 | Vtech ia5845 Twin Cordless Phone
We have Vtech phones - Modes : i6785/6786 which we purchased last 4/30/07 and they are and have a lot of static - why. Can hardly hold a conversation.
try using a corded phone(borrow one if you don't have one) see if problem is on phone line. Cordless amplify static on a phone line. If static is not on the corded try relocating the base of cordless.
May 29, 2008 | Vtech Lands Phones
Echo
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Mar 04, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
63 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
