Question about Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp 32" TV Model#32U-F500
The TV powers on, then shuts down. It use to stay on for anywhere from 30min. to 2hr. We had another TV that did the same, and the power switch was changed, solving that problem. Could this be the same?
  • Tracy hillstrom Jul 11, 2007
    My idea worked...I purchased a new switch, soldered it in, and the TV has worked since.
    Thanks leslake for your response!
  • 32 Answers
Anything is posible with your tv.
i had repaired some of these models, problems are common but solutions different.
1-mostly it is of bad soldeer connection in your horizontal output section. see if this will help solving the problem.
2-try to look for a defective cap in the oscilating section. if i am not mistaken it is 10uf/100V.
3-a defective thyristor in the power can rush too much voltage through the system what makes to go in protection.
succes and enjoy
Posted on Aug 23, 2010
    Scholar:
  • 150 Answers
It is a possiblity, depends upon why the set is shutting its self off, if for instance with your other set, the micro was probably recieveing a power off command from the button due to some moisture in the switch or something, it could be a bad connection in certian circuits that power the set also, you might try to lightly touch the power button to see if it is "flakey", if not, might require a trip to the repairman.
Posted on Jul 08, 2007
Tv shuts itself off after 10 minutes
Its a setting i think if its not what you should do is check
Dec 18, 2012 | Sharp 32U-S650 32" TV
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Dec 12, 2012 | Sharp 32U-S610 32" TV
My 32u-s650 tv won't turn on
Check for any loose solder terminals its main board.
Oct 20, 2012 | Sharp 32U-S650 32" TV
Tv has black box in the middle bottom of screen this a sharp model 32u-s610
sounds like the closed caption has been acidentally been turned on look at the remote see if there is a closed caption button if not look in the set-up menu
May 16, 2010 | Sharp 32U-S610 32" TV
Does the Sharp 32U-F810 TV have a digital tuner?
No it only supports analog. I'm pretty sure no CRT TV would be digital reception. Here is a link... Scroll down until you see the specs. First line is your answer: http://www.ciao.com/Sharp_32F540_CRT_TV_CRT__10021988#productdetail
Apr 27, 2009 | Sharp 32U-F810 32" TV
Turns on but quickly turns off
hi
you have defective power oscillations! in this model you have to replace the vertical output ic. because the power oscillation for Jungle IC is passing by from Vertical output.
Thanks!
Dec 29, 2008 | Sharp 32U-S60 32" TV
Tv repair
CHECK POWER OUT LET FOR AC CHECK CORD AND FUES FELL OUT
Jul 26, 2008 | Sharp 32U-S610 32" TV
Sharp 32U S50
Maybe a problem in deflection section. If there is a problem in these section the micom ic is trying to protect to continue anymore short circuit. Or there is a leakege in power supply section. This could be fixed by service technician only. Better to call nearby service people.
Jun 24, 2008 | Sharp 32U-S650 32" TV
Black screen come
This is due to a "Text" setting in closed caption.
Apr 14, 2008 | Sharp 32U-S60 32" TV
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
498 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
