Error Message on copier.
The Konica 7065 shows an error code of F36-2. Is there any way to override it or is there a place that I can order the part to fix the machine.
  • 126 Answers
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Posted on Jan 24, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ... > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from
Error code C-B116, what does it mean? - Fixya Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
Error code E-22-1
Please the copier model.In Dialta model the code refere to main body main motor malfunction.
Feb 12, 2013 | Konica Minolta Copier Toner 7055/7065...
Konica 7065 with an error message of F341 problem
hi code 34-1 is fuser temp fault to reset turn off machine hold down buttons 2and 5 and turn on release 2 and 5 a menu screen will show select 1 software switch settings you need to switch no3-1 3-2 3-3 3-4 to off then try if still fails there is a good chance a heater has blown in the exit fusing unit or its temp sensor is faulty definately a technician required hope this helps:)
May 31, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7065 with error code F36- 1
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Feb 25, 2010 | Office Equipment & Supplies
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
186 people viewed this question
