Tempstar sp80 limit switch - Heating & Cooling
2 Suggested Answers
FurnaceGuy
  • 74 Answers
SOURCE: i have a tempstar combine air conditioner and
If the unit is around 6 years old then it could be the combustion air motor. If the unit is older then you need to inspect the heat exchanger for signs of cracks. Take the top off the unit to inspect. Check to see if the metal around the reset is hot and if it is then the switch is doing it's job. If the heat chamber is cracked then turn the gas off, because your home will have CO. This can kill you.
Posted on Jan 05, 2010
Unit does not stay lit
A few questions for you. If the thermostat is satisfied as in turned below room temp, does the blower shut off. Are the filters clean? Furnaces have a limit control that governs how hot the heat exchanger runs. If the limit switch opens for some reason the fan or blower will continue to run until the limit switch closes. So dirty filters? A very dirty blower wheel? A blower motor that is not coming up to speed, Could just be a bad limit switch that is opening up at a lower temperature than it should. I would also check the pressure switch sensing tube. The end could be blocked with deposits
Sep 06, 2017 | Heating & Cooling
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
I have a tempstar combine air conditioner and furnace. the furnace will run fine then the manual limit switch trips. i can reset the limit switch and it will operate a couple of cycles then trip again, any...
Jan 05, 2010 | Heating & Cooling
Parts list for Tempstar PGAD60E1K1? Anyone have?
Tempstar will only sell to licensed dealer/contractors. You will have to purchase through your local HVAC contractor that deals Tempstar. They will be able to cross your model # to the correct parts. However, you must have an EPA license to purchase the compressor.
Oct 06, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
