Question about Mitsubishi WT-42311 42" Rear Projection Television
My WT-42311 TV hs spped showing yellw so the background is Pink
The background on info  shows pink and green. It has been suggested that it is my convergence ICs were at fault.  Where can I find instructions on replacing them  Owen J
  • ojsmail Jan 23, 2009
    This unit os not us CRTs is what I was told when I purchased it.
    I tried resetting the convergence but there is no response  the screen comes up but nothing happens There s no adjustment at all.SO I will try replacing the convergence ICs.
    thanks for the help. Owen J. .
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, repairs for your particular brand and model involves the replacement of STK393-xxx (110) Convergence IC and possibly a few 5Amp pico fuses.Convergence repairs has been tooled to be rather easy and user capable. Often a repair kit is available which includes the necessary components and a step by step instruction sheet. One suggested source is http://servicemanuals.vstore.ca/ owned and operated by another member expert of this site, Slinteriors
Pls postback updates. Good luck and thank you for using FixYa.
Posted on Jan 23, 2009
  • 1,031 Answers
First, it is very important that you have some soldering experience working on solid state printed circuit boards, and that you know too much heat from the soldering iron will most likely ruin the PC (printed circuit) board. If this happens, it can be a very difficult repair. The boards are no longer available for some of these sets from Mitsubishi, so I cannot stress enough - if you have no soldering experience, let a pro assist you in this repair.
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Jan 23, 2009
    et’s get together the equipment you will need to work . You will need:
    • A
      #2 Phillips screwdriver to first remove the backboard in the rear of
      the TV set as described on page 10 of the service manual.
    • A
      small soldering iron with a desoldering bulb to remove the solder on
      the pins of the IC’s. I recommend an inexpensive one from Radio Shack.
      It is a 45 watt type, .
    • A
      small amount of rosin core solder to re-solder back in the new
      convergence IC’s. You can get that at Radio Shack also.
    • Heat sink compound or thermal paste.
    • You
      also might wish to pick up a small amount of solder braid to assist you
      in cleaning up the area around the un-soldered pins of the convergence
      IC after you remove it. It is very important to make sure you have no
      solder splashes or bits of solder lying around or across any of the
      adjacent circuits.
    • ONE (1) STK393-110 convergence Amp IC. -. Yes,
      these IC’s in this Mitsubishi set is made by Sanyo. Many of the less
      expensive IC’s are not original and the aftermarket types made in
      China. I have heard also that some parts distributors buy factory
      reject IC’s and sell them as good original IC’s. That being said, it 's
      up to you if you want to be back in your set several months down the
      road because of another convergence problem. Play it safe, and stay
      original.
    • A small multimeter or DMM (digital
      multimeter) and know how to use it. You can get the five (5) amp pico
      fuses .
    you can check here foe further instruction on these http://www.techlore.com/article/22530/DI...
    hope this helps
    Genius:
  • 1,239 Answers
Hi here there is full steps and the ic part replace all u want http://www.techlore.com/article/22530/DIY-Repair-Replacing-Convergence-IC-s-on-a-Mitsubshi-TV-Set/
please post pack for further info..........
    Genius:
  • 1,550 Answers
You can get STK IC from the link below
http://www.electronix.com/catalog/default.php/cPath/6
For instruction click the link
http://www.fixya.com/support/r704766-convergence_solutions
    President:
  • 1,214 Answers
Just checking the service manual for my 65311, I would be more suspect of a failed blue CRT or associated circuitry than a convergance problem.
If I remember correctly, you can turn blue off while converging.
Do you have any blue at all?
  • Mark Egan Jan 23, 2009
    Well, it does, at least that is what they call them in the service manual.
    Brigadier General:
  • 8,619 Answers
Hi!
Care must be taken when disassembling the board for removal. Mark connectors when unplugging them. Remove all screws holding board in place. Disconnect thick red wire going from the flyback to the HV block by pushing back the boot and pushing the lead inward and turning simultaneously. This unlatches the connection to the high voltage block. The thin red wire from the flyback to the front loosen from tie downs (not necessary to disconnect/plenty of wire length). Not necessary to unsolder the heat sinks from the ICs. After bad IC removal, line up the leads on the new ICs and use patience to insert into the holes. Once you get an IC leads through, hold IC in place and screw back to the heat sinks before soldering. If convergence does not improve, check for open pico fuses. They look like resistors and have an amperage rating silk screened on the PCB.
  • Rylee Smith
    Rylee Smith Jan 23, 2009
    Just be carefull when desoldering these stk's use solder wick and patience even a pro can take an hour to desolder these so be carefull not to lift the trace or the situation will quickly get worse. don't adjust these tubes as they are set to the correct alignment already.
    Ask for any clarifications
    Thanks
    Rylee
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
LCD TV display shows pink flickering screen when using DVI > RGB cable
it's easy man when it shows u the walpaper it'sin the extanded desktop so it only shows u a part of the desktop while the other is on ur pc monitor
u need to go whereu can change the resolution and mark the selection *make this as main screen * for both vga and lcd tv done u will have clone desktop on both
Feb 09, 2013 | Nvidia Computers & Internet
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Oct 14, 2009 | Televison & Video
Pink spots on screen sony wega 42" reaprojection tv
This TV has a known problem with the optical Block. Please call Sony Customer Relation and ***** them until they send someone to replace the optical block
Jan 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
