Question about Crock Pots & Slow Cookers
Need manual for carl weill pressure cooker
How dose valve works
SOURCE: manttra 6 qt pressure cooker
visit www.manttra.com
on the bottom of the home page you would see free download for the rec book and instruction book..
Good Luck
Posted on May 12, 2009
  • 1739 Answers
SOURCE: I NEED TO REPLACE THE PRESSUR RELEASE VALVE.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
  • 1739 Answers
SOURCE: need a steam release valve for my Bristo Wolfgang
Not sure if your model is the BPCR0175 but if the part you require is not available on-line suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
headstrong56
  • 493 Answers
SOURCE: Pedrini Pressure cooker instruction book and valve
they can set you up with what you need herehttp://www.epinions.com/t-safety-valve-for-pedrini-pressure-cooker?sb=1
Posted on Jul 19, 2012
  • 475 Answers
SOURCE: need a pressure cooker manual in spanish
You could look on the internet, or call the conpany where you got it from maybe they might be able to help you, or your library in your town.
Posted on Dec 29, 2012
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Se e4 on my cooker what do i do
    The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
    Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
    I need a manual for miu france pressure cooker model 95080
    MIU France produced a video to explain how the pressure cooker works. You can view it here:
    http://www.youtube.com/watch?v=qJhVqdx7f9M&feature=c4-overview&list=UUk09IwTBUtsp_BCGLXF6QYw
    You might want to check the Free Pressure Cooker Manual library occasionally - if the manual you're looking for isn't there they'll likely add it soon!
    http://www.hippressurecooking.com/pressure-cooker-manual-library/
    Apr 11, 2013 | Wolfgang Puck Electric Pressure Cooker...
    Displays e4 wont work
    Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
    May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Error code keeps flashing wont pressure up and they wont stand behind their product
    The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
    Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Presure weight plastic is off
    You can remove the plastic cover from the vent valve and it will work fine. If you remove the plastic cap, you will need to manually tilt the valve with a utensil to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
    Feb 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Steam coming out of floating valve on handle.
    No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
    Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Cook's essentials pressure cooker float valve
    body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } http://www.wpcookware.com/manuals.asp
    look at the pressure cooker section (some other pressure cooker is showing in the photo) use the drop down menu to choose the model number of your cooker and click view, it should download as a pdf (or you can save it as one) on your computer.
    Hint: I tried this on firefox and the 'view' button would not work, so you may want to use Internet Explorer to get your manual.
    Dec 20, 2008 | Wolfgang Puck 5-Quart Electronic Pressure...
    Crock Pots & Slow Cookers Logo
    60 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
