Question about Samsung HCL4715W 47" Rear Projection Television
I smelled something burnt and a clicking noise
When the unit was on it suddenly burnt something and then is sounded like it was powering on and off. It just kept clicking and no picture. Then it stopped clicking and the picture now has three images overlapping each other in green, yellow and red. Is this a common problem and if so I hope it's not too expensive. Thanks for your help
    Scholar:
  • 150 Answers
This is a Common problem, you have shorted convergence amplifiers, some of these have a small board that is mounted behind the CRT's with a red plug/blue wire, these are incredibly easy to replace, some samsungs have the convergence circuits mounted on two tall heatsinks on a big board with the high voltage transformer (has 3 big red leads comming out of it) and requires alot more work to replace, if you are uncertian I would call the repair man, you can look to spend around $350-500 I would suspect, if you call someone might ask what convergence board replacement would cost.
Posted on Jul 08, 2007
SOURCE:
2001 ford escape has horrible rubber smell and bad noise
Remove the drive belt on the alternator and see if you can spin the pulley freely. Check for bearing noise or knocks in the alternator . If it is hard to turn then replace the alternator . While the belt is off check all other units and pulleys to see if they turn freely. Now check the drive belt and smell it If it smells of burnt rubber then replace it as it is what the smell is all about.
Feb 03, 2014 | Cars & Trucks
Electrical burnt smell
If you had a short in the starter motor windings and held the key, you'd get a click and a burning smell. That would be the insulation burning off the electrical windings. There's a 40-amp max fuse in this circuit.
Jul 21, 2017 | 1995 Chevrolet K1500
Washer had just started and i started to smell something, and all of a sudden a noise came from the washer and then smoke came from machine really bad, the noise sounded like air escaping
Looks like something is short circuited & due to which there is burning smell coming out of the machine. Disconnect the machine immediately & inspect the insides of the machine. Locate the burnt motor or burnt wires. You heard the noise coming out of the motor. It could be dislocated brushes due to which the motor could not rotate & in turn it burnt your motor.
Sep 18, 2011 | Admiral Washing Machines
Mixer is still going but making a popping noise. Also has a burning smell - maybe a wiring problem?
HI.When the stand mixer produces a popping sound during mixing this problem has something to do with the motor.Motor has bossing on it.This might not be lubricated well and eventually lossen up.That's why it produces a popping sound.And with regard to the burnt smell might be on the coil of the motor's rotor or armature.Is the unit still functioning eventhough you smeeell burnt wire?Thank you for choosing FIXYA..
Jul 22, 2011 | Kenwood KM305 Stand Mixer
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Car has a burning smell under the hood and makes squeiling noise could it be a burnt valve
NO. I would say you either have a loose belt or your, A/C or ALT. have a bad bearing.
Feb 01, 2010 | 1992 Oldsmobile Cutlass Ciera
TV DOES NOT COME ON AT ALL
Bad power supply. Symptoms: No display at all, no power indicator light, no sound from speakers, momentary popping or clicking noise, "burnt electronics" smell. Typically caused by failed capacitors. Can be usually be repalced and continue to have working display for a long time. Repair: Replace power supply. Super cheap when it's just a couple of bad capacitor to medium expense when repalcing whole power supply unit.
-=/ Daft Tech /=-
Oct 22, 2009 | Toshiba 23HLV85 Television
Kenmore fridge started having sparks and has an unpleasant smell
the compressor is asealed unit and wont cause any smell but it does have a push on starter on the compressor pins under the cover (most likely cause)
Possible other faults are defrost element or defrost timer
Jul 27, 2009 | Refrigerators
The receiver turns on riefly and then makes a
The clicking noise is the protection circuit., sounds like you have a grounded speaker wire, but you say the speakers are not connected so the amp may be toast. Is there any smell of burnt wires? This is ussuallt noticable near the circuit board if something failed!
Jul 07, 2009 | KLH Audio Players & Recorders
Noise from woofer
Double check all of your cables, but it sounds like the power supply may have died. If the sound is like a mains hum, then the power supply will need to be replaced. Is it an internal or external one ? If it's internal, are there any fuses accessible ?
Sounds obvious, but double check the speakers are all correctly plugged in, by removing and re-inserting them. Check the volume controls and and other switches too. Try plugging headphones into the audio outputs to confirm their is actually a signal present, as the speakers may be fine, but the source may be faulty or its configuration changed.
Nov 20, 2007 | Car Audio & Video
Samsung HCL4715W 47" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
