Question about Bell Televison & Video
How do you program the IR Remote 103781, tried the procedure above, don't work
Tried holding the TV button down till all the mode lights were on, let the tv button go and the tv button will keep blinking, I press the tv/video button and the top tv button will light but it doesn't stay on.
  • 374 Answers
SOURCE: IR remote 103781- Looking for control code for the INSIGNA TV
If you have tried locating your tv type in the back of the manual that came with the receiver and can not locate it then chances are that the remote does not ssupport your TV. You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Posted on Jan 28, 2009
  • 374 Answers
SOURCE: IR Remote control 103781
OK first and foremost not all tvs are supported by Dish remotes. This is especially true of combo units bbut here is the easiest way to program the remote if the tv is supported:
Press and hold the clear tv button on the top of the remote until all buttons across the top light up.
Now press the smallred tv button and release it.
The top tv button should be lit constantly now.
Now press the arrow up key slowly until the set turns off.
Once it has press the arrow down button once and then the arrow up button to see if tv turns on.
If it does press the pound key and release.
The topmost tv buttton will flash three times.
You are now ready to press the SAT key on the top of the remote and watch tv as usual controllling volume etc with the remote.
If the set turns off but you can not get it to turn back on turn the set on manually and start the process again- it will not go back through the codes you already had tried.
If you notice the tv button flashing rapidly it means you are at the last code and need to go back the other direction or that there is no code for your set.
If the set turns off but will not turn back on then you have a partial code which will not perform properly. Thanks for using Fix Ya.
Posted on Mar 12, 2009
  • 374 Answers
SOURCE: what is thecode for rca tv
Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Posted on Mar 17, 2009
  • 8457 Answers
SOURCE: I have a dish network echostar remote control
Unplug the satelite box and replug it back like about an hour later.By letting the box resetting and upgrading it softwares the remote should work again now.
Posted on Dec 25, 2010
NickF DISH
  • 36 Answers
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Posted on Jan 03, 2011
My dish remote does not work on my new RCA tv. How do I fix that?
Hey Vernon Long,
We would have to program your remote to your RCA TV. I have provided the steps to program the remote below along with a few codes to try. You can view the link provided for more codes if the ones I list don't work!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Codes: 502, 646, 633
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Our remotes aren't guaranteed to work all types of equipment, but if the codes don't work let me know here and I will try some more steps with you!
Tommy Faust
DISH Network
Nov 05, 2011 | DISH Network IR Remote Control
The number 2 remote control do not work the remote
ramoshummer,
I would need more information to provide you a specific resolution, but below I have included basic steps to programming your remote to both your TV and your DISH Network receiver.
Link for codes if needed: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If those don't solve your problem or you're experiencing a different issue let me know here or at thomas.faust@dishnetwork.com and I will check it out!
Tommy Faust
DISH Network
Sep 08, 2011 | DISH Network IR Remote Control
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
How do i get my dishnetwork remote programed to my world tv
Janicesim851, Programming the remote is pretty simple.
We don't have any codes for a World TV available, though you can check out this link for more information
In case you already have a code available I will provide both instructions to address the remote, and how to power scan the code in.
TV: 1.) Press and hold the clear TV button until all mode lights light up.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Jul 21, 2011 | DISH Network IR Remote Control
I bought a new TV and need to program my Dish network remote control
Hey scrappy32847,
Congrats on the new TV! I can definitely assist you with this and get it taken care of. As I don't know what TV you have I don't have any codes off hand available.
You can check out this link: http://www.dishnetwork.com/SupportSection/remote-setup to get the codes to program your remote. I have also listed the steps below to program that remote to your new TV.
If you need any additional assistance you can reach me here or at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Jun 24, 2011 | DISH Network IR Remote Control
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
What is thecode for rca tv
Mar 15, 2009 | DISH Network IR Remote Control
Jan 12, 2009 | DISH Network IR Remote Control
Televison & Video Logo
88 people viewed this question
Top Bell Televison & Video Experts
ray gallant
Are you a Bell Televison and Video Expert? Answer questions, earn points and help others
