Question about Home
How to remove flow restrictor from restoration hardware spray jet showerhead
Spray jet showerhead
    New Friend:
  • 14 Answers
Here is a walkthrough: http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html but you can also just call a someone who specializes in water damage to ask if it is reparable. You can pay someone to do it for you. http://www.allcarerestorations.com/Water-Damage.html
Posted on Sep 23, 2014
  • 37 Answers
SOURCE: flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Posted on Nov 12, 2008
  • 4 Answers
SOURCE: No water flow through the showerhead bracket
blow air through the part that attaches to the bracket and see if there is any air coming out if not you probably have a clog in the tube or the head.
Posted on Apr 26, 2009
rtpflh
  • 546 Answers
SOURCE: I'm trying to remove the flow restrictor from my
remove the rubber 'seal' on top of restricter,then it should slide right out.replace seal & re-install.
Posted on Oct 17, 2009
  • 119 Answers
SOURCE: shower head has little preasure or water volume.
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Posted on Mar 28, 2010
  • 299 Answers
SOURCE: flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Posted on Apr 20, 2010
I have bought several shower heads as the spray pressure is low but none have helped. The pressure is ok on low setting on half heat but too cold. On full heat its too hot on min setting. Help plz ?
The problem is that all shower heads sold now have to be low water volume. You can take the restrictor out and see if that helps. Look for a blue or white plug type insert in the fixture that has a slot on it. Pull it out and you should be good.
http://homeguides.sfgate.com/remove-water-restrictors-showerheads-27817.html
and http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html
Jun 22, 2015 | Home
Flow restrictor removal
In a shower, it is a disc located between the showerhead and the supply line. If you remove the showerhead, you will find the disc.
Aug 19, 2014 | Home
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
Kohler Loure Hand Held Showerhead
if it looks like you can not you probably need to get a cordless drill and a drill bit a make a hole through it...be careful and clean out shavings ...this works great...i am a licensed plumber and have done this when needed and this will give you a much better flow...good luck..
Apr 23, 2014 | Kohler K-14681-CP Loure Showerhead, Arm...
How to remove restricter from Speakman showerhead s2252
You would destroy the shower head trying to remove the part.
Jan 09, 2012 | Speakman S-2251 Showerhead
Delta Victorian 5-Spray Hand Shower has no
hello
of corse ... sir want to get thread tape befor trying to fix the head .
unscrew the head of the shower not the arm.
after unscrewing the head ,look at the back were the thred is, there will be a siff. thust clean out the sif, put thread tape on the head again and bobs your uncel hehe. if that dosent fix it let me know .
Jul 08, 2010 | Delta & Victorian 5 Spray Showerhead
Flow restrictors
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
I want more water pressure/volume from my sigmatherm shower faucet. Is there an ''inside the wall'' volume adjustment?
If you are looking for more flow from your showerhead, remove the showerhead and check the following.
1. Check for debris inside the connection nut.
2. See if you can locate a flow restrictor inside the connection nut. There are a few different types, but most can be removed with little effort.
3. If your showerhead has small rubber nozzles on the face, rub them with your finger while the water is flowing. This will loosen and wash away any sediment that may be present in them.
This picture shows one type of restrictor that is used in showerheads.
Jan 12, 2010 | Plumbing
American Standard Cadet 2-handle tub & shower
All you should need to do is remove the shower head and make sure that their isnt any dirt obstructing the opening ,also if their is a restrictor like you said you need to remove it.This should make a big difference.
Feb 07, 2009 | Delta & Victorian 5 Spray Showerhead
Flow restrictor
Nov 12, 2008 | Delta & Victorian 5 Spray Showerhead
Home Logo
358 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
