Question about Nordic Track Nordictrack Commercial Xm Elliptical Console
How to change belt on a nordic track commercial xm
How do i change the belt
  • 103 Answers
SOURCE: belt on nordic track exp 1000 not moving
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: how do you adjust or tighten the belt on the
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
Posted on May 20, 2010
Nordic track commercial 1750 treadmill. over the last day or 2 it has developed a humming that gets more pronounced the faster you go as well as what feels like a small vibration
Try to lubricate the treadmill deck and belt
Watch the video to know how to lubricate the treadmill.
Treadmill walking belt lubrication
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 23, 2016 | Nordic Track Exercise & Fitness
Installed new walking belt but new belt slips occasionally
there are two bolts at the end of treadmill. they need tightened up a bit to eliminate slipping.
Oct 17, 2014 | Nordic Track NordicTrack Commercial 1750
How to instructions on replacing nordictrack c2000 walking belt
check youtube.com and search Nordic Track belt. There will likely be a video from Nordic Track to show you how to do it.
Jul 31, 2014 | Nordic Track Exercise & Fitness
Oil lubricant belt
see the video and proceed according. lube the rollers bearing front+back too.
God bless you
Oct 23, 2013 | Nordic Track Nordictrack Commercial Zs...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
How do I get the motor hood off a nordic track commercial 1500
Download a manual for this model . This will make it easier to find the hidden screws.
Apr 06, 2012 | Nordic Track NordicTrack Commercial 1500...
I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
Dec 18, 2011 | Nordic Track Exercise & Fitness
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Nordic Track Nordictrack Commercial Xm Elliptical Console Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
