Question about Hasbro Hungry Hungry Hippos Board Game
Hippo head do not lift up to grab the marbles
Instructions for Allersearch Hippo Deluxe Steam Vaporiser
Some good news for you, I had also lost the instructions, so was looking for them. Then I recalled where they were, so i've grabbed some pictures of them. Hope this helps.
Jul 16, 2013 | Coffee Makers & Espresso Machines
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Put in cartridge MP130
lift the scanner lid up,, lift the entire scanner unit up,, grab the part where the paper comes out,, slightly above its is the scanner unit,, simply lift up.. the head will move to the center,, then install carts and close it..
Oct 27, 2010 | Canon PIXMA MP130 All-In-One InkJet...
What is the 'Talking Baby Hippo' app?
Talking Baby Hippo is a fun 3D character suitable for children aged 2-7 and for everyone young at heart. Baby Hippo repeats everything you say with his baby voice.
You can tickle him, poke him, feed him carrots, make him blow a balloon, give him a pacifier or make him play with a butterfly.
You can even record your own videos of Baby Hippo and share them on YouTube, Facebook or send them to your friends and family by email.
Sep 07, 2010 | iPhone Apps
Heavy steering when turning right but not left on my 1999 honda cb600f
Lift the front end and see if the steering head bearings are loose. Grab the lower end of the forks and see if you can wiggle the steering head. Adjust untill thee is no play there. If your bearings are shot it won't matter and you will have to replace them.
Oct 02, 2009 | 2001 Honda CB 600 Hornet F
Jammed short shank drill bit in ring grabber drill driver
Mix a little JB weld stick anything to head of stuck bit. let harden and pull the sucker out.
May 16, 2017 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do I remove a Canon 730 Multipass print head to clean it? The Black ink isn't printing - I've cleaned the print heads using the software, but now need to remove the print head and clean it manually...
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Jun 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Marble mouse problems
I have a problem like this with the marble mouse ... relatively easy workaround for me is if I simply grab the trackball with my fingers, lift it slightly out of its cradle, and put it back down, it starts working again. It would be better if there were some way to prevent it from freezing in the first place.
I had another marble mouse a couple years ago that did not have this problem. Eventually one of its button switches went bad so I had to replace the mouse. This is the replacement.
Feb 05, 2007 | Logitech Marble Mouse PS2/USB MSLO904360
Hasbro Hungry Hungry Hippos Board Game Logo
74 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
