Question about NetGear WGR614 Wireless Router
Netgear wirless and acer laptop/ lapt. not seeing mac address/net
I have one acer sinked up, the other acer laptop o/s xp is not seeing the network, says I need to restart my Network adapter! But I can't get it to restart, even tried releaseing ip and renew ip via ipconfig! whats up?
booboo
    Genius:
  • 1,124 Answers
Probably your adapter has one ip fixed address.
Check on the network, your ip adapter settings and be sure that the option "obtain the ip address automatically" is selected.
Go to -->> Control Panel --->> Network Connections --->> Select your connection and go to properties --->> in the center field Select internet protocol TCP/IP---then hit--Properties---Go to General and set your connection as automatically there.
Posted on Feb 11, 2009
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
Jul 01, 2011 | Siemens Efficient Networks SpeedStream...
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
I've a problem with using the WLAN with nokia
This may be a problem with your router. Routers have a feature where you can control which computers can access the network using their physical address. This is called the Media Access Control (MAC) address. Every wireless card and network card in the world has their own unique address and is represented in hexadecimal format.
You'll need to notify your router of your phone's MAC address. On my netgear router, I access the router through a browser on a computer connected to it by typing www.routerlogin.net (i think... it varies with different routers) or the gateway ip address e.g. 192.168.1.1. Find the option for MAC address management, in my netgear it's called Access Control (i think) and there should also be an option to add MAC addresses. Add in your phone's mac address and try again.
Your phone's MAC address should be located on the box it came in or under the battery of the phone. The MAC address is in the format 00:A1:B2:C3:D4:E5:F6:7A.
Good luck
Feb 17, 2010 | Nokia 5800 XpressMusic Smartphone
Ar5b93 wirless in acer 5740 laptop does not recognise 5GHz network from netgear WNDR 3300 router
5Ghz network is only for wireless G+ or wireless N compatable devices only.
Feb 14, 2010 | Acer Computers & Internet
Notebook acer 5534 windows 7 64 bit cannot connect using wireless netgear wgr614v7, the pc sees the network. Connects ok with ethernet.
Perhaps you have turned on MAC (physical) address filtering on your wireless router/access point? If so, you have to add the MAC address of your new wireless card to the allowed list.
Nov 28, 2009 | Computers & Internet
NetGear Wireless Router and connecting using a USB Modem
I think you're saying that you want to set up a Netgear from a wirless port. Is that the ONLY computer you have?
It's not IMPOSSIBLE, but it is improbable. By default, the Netgear has the address 192.168.1.1. If nothing else on your network has that address, it might be possible to plug in the Netgear, set the IP address of your computer to 192.168.1.2-254, and link to 192.168.1.1.
I didn't say easy, just possible. Easy would be to use a computer with a wired ethernet port or grab a friend with a laptop with a wired port. It's a 15-minute job.
Carl
Apr 10, 2009 | NetGear WGR614 Wireless Router
My 3 different mac laptops with airport can't connect to my wirless
Sounds like you might be accidentally connecting to a neighbour's network instead of your own. You need to go into your wireless settings on each laptop and tell them to connect to your own network.
Jan 16, 2008 | NetGear Super G WGT624SC Router...
Wirless Router
If you're able to print from main PC ,then run printer configuration disk (which you've used to configure printer on main PC) on your Laptop , Provide static IP address to printer & laptop,within same domain(like you can use class c IP address 192.168.1.x (x=2 - 251) & subnet ask 255.255.255.0 ,MAKE SURE THAT IP ADDRESS SHOULD BE DIFFERENT FROM YOUR MAIN PC ELSE THEY'LL RESULT INTO CLASH) .After that try to make a test print. If it doesn't work then check whether ports you're suing for printing are open in your Firewall inside laptop (If there is Firewall), Also win XP sp-2 Home adition has built in Firewall try to print after disabling it.
Jan 07, 2008 | NetGear DG834G Router
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
NetGear WGR614 Wireless Router Logo
104 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
