Question about Compaq Presario 700 470024-192 Notebook
I do not have any sound from my system speakers
I have sound when I plug in external speakers but nothing with my built in system speakers on my laptop. I went to device manager, system speaker properties, general tab, TYPE - system devices, MFG - standard system devices, LOCATION - on VIA PCI to ISA bridge, STATUS - no drivers are required or installed. The speakers did work then quit and now do not work.
  • 315 Answers
Here is a list of driver updates from compaq:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=uk&product=95524&lang=en
Hope they help.
Rate me if it does.
Cheers
Mike
Posted on Jan 23, 2009
I have a Sony Bravia KDL52S5100 , I connected my PS3 through HDMI and connected external speakers through the 3mm audio out on the side. It used to work fine but now the audio is not playing through my...
This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Feb 27, 2014 | Televison & Video
Sound quit on Olevia SyntaxBrillian 232-S12
A common symptom of power supply trouble is disappearing sound
Apr 01, 2013 | Olevia Televison & Video
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached.
1st. make sure the volume is up all the way.
Then try using a headphone just to make sure the sound card is working.
If the headphones work then it should be a setting somewhere.
Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing.
If they don't work the sound card may be blown but it is still possible it is not.
Also, try Keyboard shortcuts for mute and UN-mute.
Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there.
If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
Sep 28, 2017 | Toshiba Tecra M4-S435 Tablet PC
It says, that the ViewSonic PJD5122 SVGA DLP Projector has a built in 5 watt speaker. Does it? Because when i try to hook my xBox into it, there is no sound when the voume is all the way up. Also, when I...
You have a 3.5mm Audio Input jack for external audio in. ( Not Speakers) The Audio Output jack is for connecting that to a stereo system which is the best way to go. So, what you want to do is connect your xbox audio out which is probably a rca jack to the projector. I believe you will have to buy a y-adapter ( 3.5mm male > double rca fe-male) then use the standard rca audio cables. You don't plug speakers into that unit, I hope you haven't damaged the audio circuit. You might have a external audio switch within the menu of the projector to switch from internal to external audio source,,, look for that.
Dec 03, 2010 | ViewSonic Televison & Video
Just bought X-140 speakers. Plugged them in and connected them to the audio output jack on the back of my HP desktop model SR5710Y. Booted up the computer and logged on to Pandora. Got sound from the...
Most HPs have a utility in the Conrol panel for speaker jack output assignment, verify you have them plugged into the green jack not blue/pink, verify that the digital output only is not selected in the speaker control panel. you say built in speakers , are these in the monitor, some HPS have two outputs that can be controlled individually, again this is in the control panel audio properties utility, sometimes there is a audio icon by the clock (bottom right) that will also adjust these settings, but the "control panel" way is more reliable.
Aug 27, 2010 | Audio Players & Recorders
Thinkpad T41 with XP-sp3: No sound / working fine until yesterday
Hi. Try plugging in an external speaker just to test the issue. It could be just the speaker of the laptop is having the problem. If you were able to hear the sound from the external speaker then the problem is the built in speaker of the computer. If there is no sound coming out to external speakers. Try to reinstall the driver of your soundcard.
Jun 17, 2010 | IBM ThinkPad T41 Notebook
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
106 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
