Question about Mitsubishi WT-46807 46" Rear Projection Television
When i turn on the tv it comes on then shuts off right away? is this a easy fix? the tv is in perfect shape like new condition
This happened about two years ago . I called a repair shop and they said it would cost about $300.00 to fix, we havent used it since. we just bought a new flat screen tv. but now im thinking should i fix it? or ask a tv shop to take it if they want it, or should I try to sell it to them?
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Posted on Jun 01, 2006
  • 192 Answers
SOURCE: WD-52525 Shuts off, shows red lamp light even after replacing lamp
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Posted on Feb 18, 2007
SOURCE: Shuts Off After @ 60 Seconds
Some of the Mitsu *25's are covered by a factory recall of the optical engine, even if it is out of warranty.
The airflow message is a faulty temperature sensor located near the lamp. Temporary fixes (that will not void your warranty), are as follows:
Find the inlet vent, clean the filter, then place a small fan in front of said filter.
Call a repair company thats an ASC for mitsu, they will replace the sensor (not repair).
Sometimes, when the change lamp message appears, and you try a reset, it does not work. Unfortunately, this is a known problem without a known solution, other than just keep resetting it.
Posted on Dec 06, 2007
  • 1694 Answers
SOURCE: Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Posted on Jan 01, 2008
SD Tech
  • 14553 Answers
SOURCE: When I turn on the
Depending on actual model number most of these sets have a self check.
When green light goes out: On front of set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat several times.
Let me know what error code you find and comment here and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Oct 05, 2010
Have a Sony KP53S65 Rear Projection TV... while watching, it made a pop sound... the picture shrank (faded) to a small circle of color in the middle of the screen and than disappeared to nothing. There...
The tv have blown electronic components Highvlotage deflection circuitries area.This tv is not an easy fix,must hire a tv Tech.get an estamate to troubleshoot and replace components,sorry could be anythings,if it just pop and fade picture away.Well LCD tv is pretty cheap these days,compare prices a new LCD tv or fix up the old DLP tv u determine.The cosmatic appearance,mean nothing in electronics devices.
Dec 30, 2010 | Televison & Video
Picture turns on and off and the color is a blueish red
yes. you are not getting green. sony has a circuit that if the picture is not perfect, it will shut off. two solutions....one, take off back and with the tv on, tap pretty hard but not hard enough to break it, on the neck of the picture tube with the plastic end of a phillips screwdriver. this will shake the old sediments in the crt. the tv will probably shut off if you do it right. tap harder and harder many times. fixed. two, rejuvinate the picture tube. fixed. easy
Nov 13, 2009 | Sony KV-27S66 27" TV
Our tv turns on then shuts off right away and the power light turns orange then starts blinking green? what do we do?
if you have sound, search "picture goes black" on this site and you should find easy to follow instructions how to fix it.
Nov 10, 2009 | Sharp Aquos LC-32D40U Television
Tood my D52W20 to Repair man and he said not worth fixing.
The repair man doesnt know RCA 's very well. The 3 x then out power led is the classic sign of the flyback and cp150 needing to be replaced. You need the flyback # 259296 and the CP150 you can get the flyback and cp150 at the following link with free step by step instructions with pictures on how to do the repair. Its very easy. Heres the link.
http://servicemanuals.vstore.ca/
Mar 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony KV-32XBR400 television
Four blinks would normally indicate a yoke winding that was shorting intermittently, 5 blinks something on the "D" board in overvoltage condition and 6 blinks commonly Ic6501 is failing...
To have all of these blink codes happening could be signal derived, thereby not affecting dvd play. Could be smps related or possibly regulation. My first guess would be the "D" board...
Is there a cheap and quick fix, yes and no... This isn't one you'll be able test out or you wouldn't be asking the question. But a shop should be able to determine the problem and repair for less than half the cost of a new Tv in it's comparable class..
Hope this helps!
Bill
Nov 20, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
Feb 04, 2007 | Digimate DGL26 Television
Mitsubishi WT-46807 46" Rear Projection Television Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
