Question about Singer 132QRFB Mechanical Sewing Machine
Carriage on singer ke 2500 keeps catching kneedles and yarn loops
Machine hasn't been used in 20 years,has been oiled but every time try to run the carriage the yarn gets tangles and the carriage gets stuck.any help would be muchly appreciated.if you need more information regarding problem please ask.thanks in anicipation.
    Scholar:
  • 65 Answers
Take out your bobbin holder and see if there is thread clogged up inside the machine
Posted on Jan 24, 2009
How do I set the hook timing for a singer serenade 20
remove any plates so the you can see the needle and the bobbin carrier action
now turn the machine over by hand and watch the needle go down to it's lowest point
the hook part of the bobbin carrier should be near the needle
now turn the machine a fraction more and the hook should be almost at the eye of the needle so that a fraction more the hook passes the eye catching the thread
when you have the hook at the needle but the eye is too low or too high, the adjustment is by the clamp that drives the rod from the shaft at the end of the machine
loosen off the clamp and physically tap the rod clamp up or down until the eye is in position as described
retension that clamp
Oct 25, 2017 | Singer Sewing Machines
Should I oil my Singer 6235 machine?It has not been used for 20 years, but seems to sew well.
Because your machine is an older mechanical, it most likely would benefit from a thorough clean and oil. Even though it still sews well, the moving parts may be dry and need some lubrication to keep it running smoothly and quietly. At some point it very well could begin to seize. Even if it runs well, you will most likely notice a difference in the sound and operation after some TLC.
Wheel on right side that controls the needle up and down is very tight...
Oct 07, 2017 | Singer Sewing Machines
Why is the bobbin case on a Singer 4423.CL - Heavy Duty 4423 not working right?
If you've cleaned and oiled it, change the needle to see if it is catching in the wrong place and re-thread, of course. If none of that works, it's probably the timing ... find a good repair guy.
Aug 19, 2014 | Singer Sewing Machines
Singer 27
What kind of thread are you using. The most often problem today is that the thread is too thick for the size of needle. Try using a Metallica size 90 or a top stitching needle size 90
if the thread is a cotton type or a quilting thread it is often to thick to travel easily through the eye of a needle quickly to form a good stitch.
Aug 03, 2014 | Singer Sewing Machines
I think timing is correct because hook catches thread every time, but when the hook finishes its rotation and releases the thread, the thread loop doesnt make it all the way around the bobbin case......it...
the catcher/hook on the bobbin case system loosen or not fix properly probably becoz of vibration or something( check or replace new), then check upper system either tension/ tighten of your thread/yarn or correct..
Oct 27, 2013 | Consew CP206R Sewing Machine
Singer 774 - Clanking on Zig Zag Settings
I would suggest taking the machine in to have it checked, when a '
machine is taken for yearly check ups, the machine will run better
& not be a cause of worry
Jun 03, 2012 | Singer Sewing Machines
My bobbin housing seems to be messed up. I follow all the directions in the manual, but nothing helps. My bobbin stitches are looping on the underside, my machine keeps breaking needles. I'm just trying to...
Ok, if the bottom thread is looping (bottom of fabric) try adjusting your UPPER tension.
Make sure that your thread isn't catching on anything before it reaches your needle, a small snag can cause needles to break.
Jan 12, 2010 | Singer 118 Mechanical Sewing Machine
Singer 5050
Does your sewing machine create unwanted loops or does the thread snap on the top of your machine? Does it seem like your machine does not want to work with you? Your problems could be related to tension. First off, I recommend putting a white thread in the bobbin and a black thread through the needle. This will be imperative as you will need this to learn which thread is your main problem.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis. If you see loops of black, your needle tension is too loose or your bobbin is too tight. First try tightening the main dial on your machine to a higher number. If that does not work, try using a small screwdriver to turn the screw underneath the bobbin-case in the front of your machine clockwise. Please remember that even a little turn can mean everything in your work. I recommend only turning it 1/4th of a turn each time you test it. Now if the loops were white, it means your bobbin tension is too loose. Do the same as above, tightening the screw clockwise with a screwdriver. If it seems too tight, please do loosen it and try to find a happy medium between your needle thread and your bobbin thread. If the thread snaps, your tension is too tight. Do the reverse of the above. Either lower the number on your needle if the thread is snapping or turn the screw on the bobbin-case counter-clockwise. Again, each little bit of the turning counts, so only turn it about 1/4th the way. It is always good to be extra careful. Keep working with both until you get a nice even stitch. An even stitch means the black should be on the top of your fabric and white should be on the bottom. It is perfectly okay if you see a little speck of one on the other side. If all fails, try putting two drops of sewing machine oil in your machine and let it run through for about five minutes. The mechanisms might be a little overworked and are having a problem with your machine. It is good if you keep a lot of fabric scraps available in case you over oiled. You do not want to be working on a difficult project for your sewing machine only to spit some oil on it. Keep sewing on the fabric scraps until there is absolutely no residue from the oil. Putting any more that 2 drops as stated earlier might cause more problems than you expect. Always use the oil sparingly. If none of the above solutions have worked and you feel frustrated by your machine, a local Sewing Repair Shop visit should only run you about $40 and is highly recommended for your machine. A professional can tell you if what’s wrong with your machine is fixable at-home or not. A full repair for older machines before working with them is highly encouraged.
Sep 15, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 132QRFB Mechanical Sewing Machine Logo
88 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
