Question about Swiss Army Victorinox 241131 Watch Night Vision II Mens - Black Dial
Need to replace black bezel on 241131 watch - Swiss Army Victorinox 241131 Watch Night Vision II Mens - Black Dial
I need to replace the bezel of my nautica divers watch from black to red and white combination . A151026 model
ALL NAUTICA WATCH BAND OPEN THIS LINK IN EBAY
http://www.ebay.com/sch/bluss_929/m.html?item=321576294387&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Feb 27, 2015 | Nautica Watches
Purchased a new 18k gold bezel to replace the bezel that has the gold worn off.
whats the problem are you trying to fit the new bezel? you will also need to ensure the bezel retention spring is with the bezil
Apr 10, 2014 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have an older skyhawk watch, but the paint came off the bezel so you can't read the numbers. How much would it cost to get them repainted or replace the bezel?
I had the same issue. I found a way that makes the watch look new again. If you buy a sharpie marker and color the whole face It will color in the numbers and around them. t After you have done that, rub a moistened rag over the face of the watch. This will remove all the excess black marker, and it should look new for a few months.
Dec 19, 2010 | Citizen Blue Angels Skyhawk Watch
The black plastic ring, w/ white markings (bezel ?), that goes on the metal (dial) which moves around, fell off. Is this part avail., and if so, for how much ?
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Apr 24, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
I need a replacement watch strap.
Most watches have a similar strap fixing method, so you might be able to get a replacement strap from any watch retailer.
The shop should be able to advise you if they cannot provide you with a replacement.
Mar 01, 2010 | Watches
Need new bezel
Try parsecent.com, you can get a replacement bezel there...
and you are right, you are basically buying a new watch as this model is made of plastic and cannot be 'polished'. Refurbishing it means that it will look new and everything on the outside would have to be replaced...good luck :)
Aug 07, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
I need to change the bezel on an older Tag Formula 1
I'm sure any watchmaker can do it for you. I've had one pop off an old one for me an replace it with a slightly used one he had. I would like to replace that with a new one. They're available in the UK, but they're pricey. Ebay is an option.
Nov 24, 2008 | Tag Heuer WAH1112.BT0714 Formula 1 watch
Swiss Army Victorinox 241131 Watch Night Vision II Mens - Black Dial Logo
27 people viewed this question
Top Swiss Army Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Swiss Army Optic Expert? Answer questions, earn points and help others
