Question about Nokia 6085 Cellular Phone
I get no rings but it vibrates - Nokia 6085 Cellular Phone
    Scholar:
  • 76 Answers
i get no rings but it vibrates - 6085_96x96.jpgHttp://www.nokiausa.com/get-support-and-software/software/device-software-update/download-o1 i pasted this update for your phone. click on the image that refers to your phone. your phone might need update. if update fails refer to your volume settings. tapping on the volume to full or having someone call you
Posted on Jan 23, 2009
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
May 29, 2009 | LG Shine KE970 Cellular Phone
Cant get the phone to ring. it is set to vibrate & ring but only vibrates
Set the ******** off and see if it rings otherwise try any ringtone as your default callertune and observe if the speakers ring. If not then best to take it to a technician...........sodeep
May 04, 2009 | Motorola Mobility W375 Cellular Phone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
Dec 12, 2008 | LG VX8300 Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Blackberry 8300 curve
Turn your vibrate off. The curve vibrates before it rings, it won't vibrate and ring at the same time. So with the vibrate off, you will gain about 10-15 seconds of ring time.
Apr 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Nokia 6085 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
