The button I push on my 2004 pc sticks and it won't hardly work to turn on my pc. Should I just leave the computer on to save the switch?
    Master:
  • 413 Answers
Well the problem with that is if you leave the computer on it will have to be restarted at times. Which should be fine if your computer will reboot by itself.
Or you could buy a new computer case and switch all the components into a new case. Of course you could always mickey-mouse it by wiring a switch you can find at a computer parts store or another old case. But you would have the switch wires and all coming out of the case
Posted on Jan 23, 2009
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
ASRock motherboard AliveNF6P-VSTA----Every day when I try to switch on my PC it won't start. Than, after about 10 attempts it swirtch on normally!
Hi, The least thing would be a faulty on/off switch, otherwise it needs setting up better in the BIOS & if you don't know what your doing you can scrap your computer really easy, The best thing is go to PC shop it should not cost very much £25 max to reset the BIOS. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
My computer i in sleep mode
Sounds like it is locked up. There should be a power switch on the back. Switch it off, leave it off for a few minutes, then turn the back power switch on again and push the front power switch. If no rear switch, pull the plug. Windows doesn't like hard power downs, but if your system won't recognize the keystrokes or mouse movement, tere is nothing else you can do.
Oct 31, 2012 | HP Computers & Internet
The power driver's seat on my 2004 Tahoe Lt won't move forward but all of the other button options work. Any suggestions?
more than likely it is the power seat switch itself try pushing on theforward button really hard onc and if it now moves get a new switch
Sep 24, 2012 | 2004 Chevrolet Tahoe
Cant turn off rake lights
brake light switch is sticking, should be connected to underside of dash (brake pedal shaft rests on it.button style. possible fix wld be spray with wd40 or like lubricant and push button in and out few times if that won't work then need to replace the switch. usually not too expensive 10 to 20bucks
Sep 08, 2012 | Honda Civic Cars & Trucks
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Shuts down as soon as i turn on my hp 530. is it the hard drive?
unplug everything. take out battery, leave out 10 sec. put back in. if it still dont work. hit with hammer, but first stick a pin in the hole, by the button you push to get out CD, DVD. ECT.... and get out your disk.
Jul 03, 2010 | HP Computers & Internet
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
The on off button on the hp processor a124on pavillon sticks.
If you grab a hold of the lower face of the PC and pull it off you will be able to see if anything is jamming the button or if the button is broken if so just use the small grey button behind the Bigger button on the face to turn the PC on..
If that makes no sense i apologise hard to explain
Good luck
Carl
Dec 01, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
David Payne
David Payne
