Question about Dewalt Dw368 Dw368k 725in Circular Saw Kit
How do you get Dewalt DW368 back in its case
How do you get it back in its case?
How do I put the dewalt dc390 back in the case?
Have you tried to remove the battery and put it in separately?
Sep 21, 2014 | Dewalt DC390K 18v Cordless Circular Saw...
I have a dewalt 28402 grinder. I have replaced the pinion but I don't know how to get the helical gear out of the case to replace it. Any thoughts? Thanks Chris
You can buy the pinion gear as a seperate part but not the ring gear. Dewalt only sells the ring gear as a part of the gear case assembly, PN 623586-00.
Oct 28, 2010 | Dewalt D28402K Heavy Duty 4 - 1/2" Small...
I want to change the brushes in my 18v xrp drill but not sure how to and which ones to buy? thanks
Without exact make and model number I can't tell you which brushes to get. 18V and XRP are usually associated with Dewalt model tools. The Dewalt brushes are located on the back of the motor inside the case. You have to remove the transmission from the front of the case, be extremely careful that no gears fall out when you seperate the trans from the case. The case has to be split to get at the brushes, replacement of the brushes is easy. When reassenbling make sure all wires are properly tucked away and don't get pinched and that the trans is put back on correctly.
Aug 23, 2010 | Garden
I can't figure out how to put the saw back in the case. i can't get the case to close. i tried for about a half hour and gave up!
Usually the saw has to be set at it's shallowest cut to get it back into the case and close the lid. I learned the hard way too, years ago. LOL
Jun 21, 2010 | Dewalt DW368 Heavy Duty 7 - 1/4''...
How do you get the dewalt dc 390 cordless saw back in the case. darndest puzzle I ever saw
Take the batt. off and drill bit out. Also make sure you are putting the drill away on the correct side of the case.
Apr 17, 2010 | Dewalt Saws
How do you put the DeWalt DW367 circular saw back in its case??
Just figured it out ourselves: with case open and facing you, place the saw in, blade facing you. It needs to go down at an angle so the "leveler" is resting on the tlted portion of the case. Make sure the cord isn't hanging out.......took us about 1/2 hour to do it. Ours was a dewalt 368; next time we'll take a pic before taking tools out of their cases! hope this helps.
Feb 25, 2010 | Dewalt Saws
I have a dewalt DW368 Circ saw, which has problems making square cuts because the baseplate flexes allowing the blade angle to change. Is this a known problem? I can easily flex the baseplate 1/8" side to...
I have never had that happen to me and I have owned atleast 30 circ saws. If the plate itself is flexing and not just movement on loose armature then I'd say it is a defect in the casting of the baseplate.
Feb 05, 2010 | Saws
How can I take a part my dewalt 12 volt drill
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
Jan 01, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Dec 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
Dewalt Dw368 Dw368k 725in Circular Saw Kit Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
