Question about Sharper Image SHP920 Wireless Headphones
Hooked up to my TV , but all I get is radio stations
How should it be hooked up with a TV and Sat. Rec.
I have an old school Sirius satellite reciever with the orange backlight, I forget what station the car radio needs to be on.
TURN ON YOUR SAT. RADIO & PUSH SEEK ON YOUR FACTORY RADIO TILL YOU GET TO THE SAT. RADIO STATION.
Mar 16, 2012 | GPS
While my FM setting works perfectly, I can't pick up any stations in MW or LW. Any Advice?
Check with an Audi Dealer. There are some stations that went Digital along with the TV stations. Your receiver may be outdated.
Oct 22, 2011 | 2004 Audi allroad
I have an ILO HDTV. I try to change the station with the remote but the TV only changes the station between 2 and 22. It doesn't respond to my commands when I want to place it on channel 3 for my...
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work.
The Poodle Guy!
Nov 21, 2010 | iLO 2600 Television
Lack of receive on a ranger 2950
Bad mic? dirty mic pins? If the mic is bad, you will have no receive.
Nov 10, 2009 | Ranger RCI-6900F-25 CB Radio
2008 dodge ram REC radio
i only recived the channels
Mar 19, 2009 | Alpine Car Audio & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Sony receiver sound
what is hooked up to the input of the tv/sat inputs?
it may be the recievers input has a component problem or the output device hooked up to the reciever
Nov 06, 2008 | Sony STR-DG800 Receiver
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Sharper Image SHP920 Wireless Headphones Logo
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
woodzowl307
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
