Question about Yamaha RXV471
Rx-v471 won't turn on
The power cord is plugged into an outlet that works, but the power won't come on
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
Yamaha RXV471 Logo
151 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
