Question about Panasonic ES8103S Nanotech WetDry Men's Electric Shaver
Battery for ES8103S
Need product number... to replace original battery for panasonic shaver ES8103S.
4 Suggested Answers
SOURCE: How do I replace the battery in a Panasonic ES8068
I need to know how to replace the batteries, but I don't plan on spending money to find out, I didn't realize your site charged for the answers when I gave you my EMail. I can probably just open up the case and figure it out myself, I just wondered if anyone else hade done it and had any tips.
Posted on Jan 02, 2010
walesarumi
  • 6993 Answers
SOURCE: Battery in Panasonic ES8183 wet and dry shaver
A 12 months old wet and dry shaver must have a defective battery after such long period of use.
The battery cell is weak and unable to hold charge.
You sure need a battery replacement. It's not necessary you get a Panasonic battery replacement as long as its the same size, shape and watt. You can get another battery from any electronics accessories store within your vicinity.
All you need do is disassemble the shaver, remove the old battery, use it as a sample for the replacement so that you can get the same battery size, shape etc..
To disassemble the shaver, first, take the shaver outside and use a can of air to clean the shaver. Repeat this at various stages of the dis-assembly, being careful not to lose any parts!
Remove the two screws at the bottom (the end that plugs in to the charger) of the shaver, and remove the bottom cover. Keep track of the two small washers, and a small flat plastic piece, about 10mm square that fits inside of the cover - these keep the unit waterproof.
Open the shaver head, and remove the blade assembly from the white plastic vibrating arm by pulling on it - it will pop off. Undo the two screws on either side of the arm, keeping track of the two small washers under the plate - these will tend to stay in place and stick to the metal plate or the plastic underneath the plate.
Press on the mechanism from the end you first opened, and notice a gap opening up where at the other end, just below the head latch button and hinge. Gently pry open this crack, and work the case apart. Keep the large O-ring that seals the case, and make a note of its orientation so that you can assemble it the same way.
This has been too easy, I know, so there is one headache. I have not figured out how to remove the sliding trimmer assembly. Because of this, I found it was necessary to pry the large black U-shaped plastic clamp from the vibrating arm at the same time you pull the innards out of the case
By now you should have access to the battery, and proceed for the battery replacement.
I hope you understand the above.
Good luck.
Posted on Mar 01, 2011
brector3
  • 1600 Answers
SOURCE: I need batteries for a
Panasonic doesn not make their shaver batteries available to consumers. However, you will find a compatible battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Posted on Apr 11, 2011
Require replacement for panasonic shaver es8003 where can i get the battries
The original Panasonic batteries are not available to consumers, however, you will find suitable batteries at shaveroutlet.com. See link below
Nov 10, 2010 | Panasonic Linear ES 8003 W Electric Shaver
ES 8003 needs new battery, new blades ?
You will find foils and cutters for this model at shaveroutlet.com. See links below
http://shaveroutlet.com/panasonic-wes9080p-cutter-blades-p-85.html
http://shaveroutlet.com/panasonic-wes9081p-shaver-foil-p-86.html
Original Panasonic batteries are not available in the market, however, there is a suitable replacement. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Apr 03, 2010 | Panasonic Linear ES 8003 W Electric Shaver
Have Panasonic ES8093 shaver.charge indicator never goes below 80%.Therefore never fully charges.
this problem is usually from old batteries. batteries will typically lose much of their ability to hold a charge after 3-6 years and they will need to be replaced.
if you use your shaver wet or rinse it under water, I dont suggest that you repair it as you will not likely get it sealed back up well enough to prevent it from leaking.
Panasonic does allow the sale of their specialized shaver batteries to consumers. Therefore, you will need to use a compatible battery type. shaveroutlet.com sells a set here:
These are made for Braun shavers but will work because they have prongs on the ends to snap in place like your originals
Jan 03, 2010 | Panasonic Health & Beauty
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Panasonic ES8103S Nanotech WetDry Men's Electric Shaver Logo
153 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
