Question about Electrical Supplies
Need transfer switch manual for generac model # Oe7969
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Posted on Jan 23, 2010
I have a generac model 04760 had electrision out check all power from generator too panel and found that there is a problem with control logic board. He can't get part or service they want him to take...
Yes. He is not a qualified generac technician or dealer. Sound like you need a control board. I recommend you find a generac authorized dealer to get a Tech out to fix it. I do it everyday at this electrical company.
Oct 08, 2010 | Generac 100 Amp 120/240-Volt Transfer...
I bought a Generac 17kw with automatic transfer switch. I would like to use a 200 Amp manual throw transfer switch. The generator came with a pre wired sealtite pig tale and junction box. Inside the...
If you are using a Manual transfer switch, then you should manually operate the system. Why don't you use the switch it came with? Why would you use a 200a manual transfer switch on a 17kw generator? The idea is to move your critical circuits into the transfer switch panel. Then it would operate in auto.
Jul 02, 2010 | Generac Guardian 200 Amp Transfer Switch...
I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Oct 03, 2009 | Generac Electrical Supplies
I need to purchase an aluminum allen head load
From Generac only. And they wont sell it to you if your not an authorized dealer with a Business license. You ll have to get it from a generac dealer like an electrician business. I know because we sell work on and istall them everyday where i work.
Jul 09, 2009 | Generac Guardian RTSE200A3 200 Amp...
Generac control wires
just 4. I install generac switches and generators
Apr 17, 2009 | Generac 100 Amp 120/240-Volt Transfer...
Electrical Supplies Logo
199 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
