Question about Maytag LAT3600A Top Load Washer
Washer was in fill cycle and stopped
Maytag model LAT8840BAW. I checked the top panel fuse and it was blown so I replaced it. New fuse blew immediately.
    President:
  • 1,214 Answers
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Posted on Jan 23, 2009
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Fuse blows on Maytag A9800 Top Loader
Usually caused by a faulty door switch assembly.
Check to see if there are TWO switches being operated by the door, the smaller of the two often fails.
Oct 24, 2017 | Maytag Washing Machines
15 amp a/c clutch fuse keeps blowing. why is it doing this?
Sounds like the magnet in the a/c clutch has failed.
Jul 02, 2012 | 2001 Oldsmobile Aurora
I have a Triumph Adler Royal Satallite III model typewriter. I replaced the blown 4 A 120V fuse and the new one blew immediately. Is there something else I can check? Thanks. Phil pnkeppel@att.net
check if it is a 50hz or 60hz.
checkthe motor has water in it or is moisten.
check the cable for cuts.
and check if you get 120v. or more than that?
unaasp192
Apr 07, 2010 | Royal Office Equipment & Supplies
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer model LAT9306AAE won't come on - replaced blown fuse in machine & it blew again right away.
Fuses are there to protect from overheating and further damage to the appliance and/or wiring. A blown fuse is seldom ever the root cause of a problem... It is a symptom of a short or overload somewhere else in the circuit.
Check wiring to be sure there are no bare wires showing or shorting out against each other or the frame of the machine. Check that drive and pump motors turn freely (with power cord unplugged).
Your problem is NOT the fuse alone. Replacing it without correcting the root cause will result in yet another blown fuse.
Jan 01, 2010 | Maytag Washing Machines
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Blowing fuses
[double post]
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Maytag MMV5207A Microwave Oven
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LAT3600A Top Load Washer Logo
180 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
