Question about SanDisk Sansa Clip MP3 Player
SanDisk sansa 1gb issues
I turn it on and only get wgat i guess is the start up screen and then it freezes there what can i do?
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Jan 29, 2009
Sansa c240 (1GB) MP3 Player: i have a sandisk sansa c240 and a 2gb micro sd car...
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
May 17, 2010 | SanDisk Sansa c240 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Sansa 250c freezes at SanDisk and the Rat startup screen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 15, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250
First, the player has to be reset - see your manual for details
Second, if it freezes after reset, then your firmware has to be upgraded - the upgrade was at the Sandisk website, but I've heard rumors that they have taken it down - which will require you to make a phone call to Sandisk
-Tha Mp3 Doctor
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Sandisk sansa mp3
k, so now the SanDisk sansa m240 1GB mp3 player, when you turn it on, it freezes. I have tried to change the battery and everything and it still wont work. What is happening here? others that have had the same problem. I researched this online and found out that there was a rather large bad batch of these mp3 players shipped in December. they suggest calling sandisk tech support at 1-866-726-3475 for a replacement and getting a RMA number or going back to where you bought it and exchanging it.
Jul 09, 2007 | SanDisk Sansa m240 MP3 Player
Mp3
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240''s there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that''s frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately. <>
May 04, 2007 | SanDisk Sansa m240 MP3 Player
Sansa E260
-Tha Mp3 Doctor
Mar 25, 2007 | SanDisk Sansa e200 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
Freezing
Same problem is mentioned in another location at this site. It happened to me too and nothing works. The standard recommendation is to take out battery and hold down power button for a minute or more, but that did not work for me. Everyone says they took it back which is what I'm going to do.
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
