Question about Nordic Track Exercise & Fitness
I need reset the drive motor of a ntl 15909
Its locked in the up incline position
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
Posted on May 06, 2010
Afton treadmill showing error code E-4 and not starting?
E4:
incline
wire 1.incline motor VR wire not on right position. 1.rework the VR cable head to be sure on right position. 2.incline motor AC wire not on right position 2.incline motor AC wire insert again to be sure right. 3.incline motor connect wire is broken. 3.change connect wire or change the incline motor
Jan 12, 2018 | Exercise & Fitness
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
Sportsart treadmill error 7
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 04, 2014 | Exercise & Fitness
Sportsart 3000 treadmill problems
Mar 25, 2013 | Sportsart Exercise & Fitness
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 27, 2012 | Exercise & Fitness
Error 7
Incline calibration is necessary when: the display shows ERR7, the drive board incline error LED ( LED5) lights or the incline has extended beyond its normal rangeThe goal of calibration is to synchronize the incline set mechanically and electronically. Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe. Electronic calibration sets the variable resistor (VR) value to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Readings of VR voltage (blue and green wires) should show around 1.20 VDC at the lowest position and around 3.80 VDC at the highest position. If the VR looses calibration or cannot be set to 1.20 VDC, replace the VR. If the incline motor gets voltage from the drive board but fails to operate, replace the incline motor set. If the incline fuse blows again and again, replace the incline motor set.
Jan 19, 2012 | Sportsart 6300 Treadmill
Our treadmill is locked into the 12 degree ramp mode and will not go down. We have tried the reset button, tried turning off and reset, but it is still locked and will not go down. What could be the...
The incline sensor is probably defective and let the incline motor physicall jam against the stop. About 50% of the time a new sensor will cure the problem; otherwise, a new motor with the sensor is the cure. Either way the incline motor must be removed to address the problem and I would reccomend leaving this to someone with experience as you could possibly injure yourself trying to attemp this without the proper knowledge. The weight of the teadmill is on the incline motor and that is where the risk is.
Dec 31, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Jul 28, 2010 | Proform Exercise & Fitness
May 02, 2010 | Exercise & Fitness
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Exercise & Fitness Logo
66 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
