Question about Directv RC65 Remote Control
How can I set my remote rc65rx to rf mode? - Directv RC65 Remote Control
Program direct tv remote rc65rx
Hi, if you are programming the Direct TV remote you will need to get the codes from Direct TV, Thanks, JT
Mar 05, 2015 | Onkyo TX-NR727
Code for rc65x
http://www.ezremote.com/setupcodehelp/DTV2/dtv.html?product=DIRECTTVRC65SW2009
Is the top switch all the way to the left? What type of receiver? Receiver might be rf mode. Is the remote different from your original remote? Press 'menu' go to 'settings & help' or 'parental, favs, & setup' then 'settings' or 'setup', then remote control. Go 'advanced ...' and check ir/rf mode. If it is exactly RC65X then the receiver should be set to IR.
Jul 07, 2014 | Directv RC65 Remote Control
I have two RC65RX remotes set for RF. One operates the DVR from one room and the other operates it from another locally. Both remotes have a problem with making the receiver work properly. If for example I...
On r15s, for rf, you need an antenna on the remote f-connector. I usually took coax with one connector on it and the other end strip 6 - 10 off with only center conductor exposed. The rf board is on the same board as the modem. Not the front panel board. Frequency is roughly 413 - 417mhz. All coded by the last 6 of rid number.
Dec 26, 2013 | Directv Used Original RC65X Remote Control
I have an Orion TV Model TV1934A and no original remote for it. I have a few questions. Could a universal remote be used for it? Could a universal remote change the TV input mode? Is there any other...
You could try a universal remote and it might let you select the aux input on the front of the set. If this doesn't work you could try an RF modulator that would feed the signal from the device you want to view on the tv through the antenna jack on the back of the set. Electronics retailers in your area should have one. Follow the instructions that come with the RF modulator.
I hope this is some help to you.
Bobya.
Jun 08, 2011 | Orion1934 19" TV
My Sony Bravia doesnt work with remote control, with any remote including universals
You didn't include the Sony Bravia model that you own - so I can't be more specific. If the TV is set up to use RF (radio frequency) codes instead of IR (infrared) codes; the universal types probably will not work. This is because most universal remotes are the IR type.
The remote included with your TV may have inadvertently be switched to send the codes as an IR type while the TV will respond only to RF type codes. It may also be that the TV was changed to respond to RF codes only. Either way, check your manual (or your TV menu settings) to see how to set the TV and the remote to work in the same mode.
If you can't find your manual, reply with your TV's model number - and if possible the remote's model number, too. I'll see what I can find that is specific to your TV.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 06, 2011 | Televison & Video
Can't program rc65 directv remote to control hr21-700 receiver
I believe the codes 00001 and 00002 are valid for all DirectTV receivers.
Instructions for entering the codes are here.
Instructions for searching for the proper code if those two don't work, or for other devices, are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Jan 25, 2010 | Directv HR21-700 DTV Receiver
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
Mar 04, 2017 | Televison & Video
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
My Direct TV RC64R remote won't work
Yes 10030 is the code. Many Thanks to the Guest.
Sep 29, 2008 | Televison & Video
Directv RC65 Remote Control Logo
152 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
