Is there and extension you can get for the Logitech Z 5300 SoundTouch remote control. Just a convenience thing so I can but the remote on my desk Thanks
3 Suggested Answers
cyrylthewolf
  • 143 Answers
SOURCE: no digital SoundTouch control center Logitech Z-5500
The very same problem I ran into when I received my new ones today...
But from the get-go, I figured that I could either use the speakers in conjunction with the new set to create more sound...or use the speakers with other systems.
Keep in mind however that speakers from one system may not act or sound the same on another system.  The difference being that one set of speakers could be your standard 8-ohm speakers where another set could be...say...  4-ohm.  Typically, the less resistance a speaker has, the better quality it is and the more sound it can put out without taking damage from the higher current.  (Lower number = better.)  You can mix speakers of variable resistances if you like.  It shouldn't be a problem - UNLESS you are going to be using them at higher volumes. If that is the case then you are going to be pushing out more current through the speakers.  The lower-resistance speakers may handle it just fine...but those with higher resistance have a higher resistance for a reason.  (Normally that is because they can not take the higher wattage.)  Otherwise you may simply experience different results in sound quality.
Be aware, however....  Depending on the quality of the speakers and their manufacturer; this may not always be the case.  It is simply a general principle of electronics and a good one to work by.
Me?  Given that I now have EIGHT satellites and TWO center channels now...  I'm going to attempt putting two speakers to each channel and elevate the second one.  This should turn my office into a veritable ocean of sound!  :)
As for a cabling or pinout schematic...  You'd have to specify for what exactly.  An educated guess would tell one that you want to possibly create your own box of sorts to control the sound system.
It's probably not worth your time.  If you really wanted to, however...  You might consider creating your own very basic inbput/output system for it that would include an amp system to drive the sub and use crossovers for the satellites.  If one could figure out the internal systems of the sub-woofer, you would most likely be able to use the amp and any I/O system that is built into the sub.  That would require a bit of electronics background, a soldering iron and most likely a LOT of patience.  There is more involved in that process than I could explain here.  (I haven't even opened up my old sub yet.  Should be fun...  Looks like it just takes a hex key to the front of the sub to open.)
Whatever you do.... PLEASE be careful!  There are going to be plenty of amplifier circuits in there...and I can tell you from experience that they can give you QUITE a shock.  (Or even explode; as in one situation I experienced.)
Any more questions?  Let me know.  But that's just about it.
Cyryl
Posted on Nov 01, 2007
SOURCE: service manual logitech z 5300
Enclosed Image is from Z-5300 Manuel
Posted on Jan 21, 2009
How do start up program for reomote to operate ty
The Google Fiber remote control is not designed to fully control external audio equipment. Although you can control basic functions like volume up and volume down, if you want the convenience of using one remote to control all of your devices (TV, Google Fiber TV Box, and audio equipment), you might consider purchasing a universal remote control, such as the Logitech Harmony remote.
Dec 04, 2015 | Televison & Video
Bose SoundTouch 20 won't connect to internet radio --> 1029 error
Hello, i had the same Problem.
Remove the Soundtouch App from your PC and reset Bose Soundtouch ( press 1 and Volume - ) install Soundtouch App new, follow the instructions and let the default settings.
Do Change not Network Name Bose Soundtouch...
Skip Music Libary from iTunes or Windows Media.
Dec 25, 2013 | BoseĀ® CORPORATION Bose - SoundTouch 20...
Logitech Harmony 880 remote control repair for volume and channel buttons
Hi. Unfortunately Logitech does not provide repair service for any products, so unless you are good at electronics and soldering this might not be an easy thing to fix. When my old Harmony 550 has button issues, I called Logitech about it and they gave me 50% off to upgrade the remote. This could be a good option for you.
Regards,
D
Aug 29, 2011 | Logitech Harmony 880 LCD Remote Control
Logitech Z-5300 Turns off and on by itself
Hi...
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
-Vash_Stepler
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
Harmony 890 Freezes
I called Tech Support, and they walked me through a firmware upgrade, and an update.
Step 1. Hold down "OFF" button, and remove the battery. Step 2. While holding "OFF" put battery back in. Remote will now enter "Safe Mode"
Step 3. Plug Remote into USB. Step 4. Go to Support -> Downloads -> Firmware from the app. It should update the firmware.
Run the update again, but this time, the only thing I did differently was plug in the remote on the screen whic said: "Done updating Extender, remote to be updated next" rather then the next one. The update went through this time.
Jan 07, 2009 | Logitech Harmony 890 LCD Remote Control
Service manual logitech z 5300
Nov 28, 2008 | Logitech Z-5300 Computer Speakers
Video performance question
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
Apr 05, 2008 | Denon AVR-2801 Receiver
Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
Mar 03, 2008 | Logitech Z-5300 Computer Speakers
Speakers All Cut out Including Sub When Music is Played Loud
UNPLUG THE GREEN WIRE FROM THE COMPUTER AND PLUG IT INTO A CD PLAYER IF IT WORKS BETTER ON A CD PLAYER THAN THE COMPUTER IT SELF THERE MAYBE A PROBLEM WITH THE SOUND CARD AND ALSO TRY THESE STEPS I AM GOING TO GIVE YOU I AM SURE ONE OF THEM WILL WORK.
1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
3. Ensure that the SoundTouch remote control is firmly connected to the back of the subwoofer.
4. Connect the power cord from the subwoofer and connect it to another single power outlet in your house. If you have an automated voltage regulator (AVR), please connect the power cord through the AVR instead of connecting it directly to a power outlet in your house.
5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
6. Turn on the Matrix Mode ON. This option is on the SoundTouch remote control. This is to ensure all speakers from the speaker system will produce audio that will be played from the audio device.
7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio device.
IF NONE WORK TRY THESE STEPS:
Jan 12, 2008 | Logitech Z-5300 Computer Speakers
122 people viewed this question
 Grubhead
Grubhead
