Question about Amana 3.2 cu. ft. Top-Load Washer
Wont agitate on its own
I have a amana washig machine its top load and only 3 tears old. It fills up and instead of agitating it hums .If i wiggle the timer it starts agitating.Is it my moter. ? thank you John
  • 65 Answers
IT SOUNDS TO ME LIKE THE START CONTACT IN THE TIMER IS NOT MAKING A CONNECTION UNTIL YOU PULL OUT ON THE SHAFT OF THE TIMER. MOST TIMES IT NEEDS A NEW TIMER.
Posted on Jan 27, 2009
Will not agitate
your transmission is locked up.
May 20, 2010 | Amana DLW330RA Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer wont agitate with med - large loads
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Jan 11, 2008 | Amana ALW880WH Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
138 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
