Question about Admiral Dryers
I can't open my dryer. model LNC7744A71
I'm trying to open the dryer. it is not heating and it sounded like an "extra part" was rolling around outside of the barrel last time it ran.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
The top of the dryer Pops up by placing a putty knife under each corner between the lid and the body pushing in on clip. then there are screws at bottom of front panel remove them. then front panel should lift up and to the side, showing drum. fan wheel.
Posted on Nov 11, 2017
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
Illeagle
  • 525 Answers
SOURCE: HOTPOINT Aquarius VTD00 Model. The dryer
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 08, 2008
danromarris
  • 101 Answers
SOURCE: dryer does not get hot
Most likely your heating element has gone bad. This will happen from a number of different things ranging from just plain age to clogged vents causing it to overheat and go out. Also with a gas dryer your thermostat may be bad. The thermostat tells the dryer when to release the gas and ignite the flame to heat the drum. This would be my first suggestion on what the problem is. There is also a thermal fuse on your dryer that may be the problem but I really think it's the thermostat. It's hard to say without hooking a volt meter to it to find where the current is stopping but these would be the most common causes. It's always a good idea to have your vents cleaned out at least once a year and if you have a long distance between the dryer and the vent outside get the entire hose cleared out yearly. This will save you money in the long run on parts and save you from any fires. With gas dryers, I have seen it a few times in homes, the lint catches fire due to the open flame and does a lot of damage.
Do try out the thermostat first, it shouldn't cost you but around 20 dollars for it. If you open up the back panel of the control panel you will find the wire diagram and it will show you where the thermostat is located. Do make sure to unplug the dryer first though. Trust me, 110 volts of electricity is not a fun feeling for anyone, I know from experience. If you have any other questions let me know. I hope this helps you out enough to get this fixed, I know what a pain it is to have your dryer out. Good luck.
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Posted on Apr 26, 2010
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    How to check and replace dryer's heating element for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity electric Dryer -...
    unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
    Oct 01, 2011 | Dryers
    Won't tumble. Drum won't roll. How do we open it
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Sep 11, 2011 | Kenmore 62702 Electric Dryer
    Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101';
    Aug 11, 2011 | Dryers
    Hello, I need some help to fix my Gas dryer. When I turned on the dryer, I noticed the sound of rolling in the box. But the dryer is not heated up at all. Manufactuer / Model : Kenmore Gas Dryer...
    gas dryer is on the right, it sounds as though the thermal fuse is bad, you can tape the wires together to test to see if it heats. As far as the rolling sound I would say it is the drum rollers:
    http://www.applianceaid.com/dryers.html
    Good Luck Tim. if you need further assistance just ask.
    Dec 25, 2010 | Dryers
    Need to know how much heating coil cost on my 70 series kenmore extra capacity dryer.
    open dryer door and get model # 3 numbers a period and 6 more #s, they varry in price from $30.00 to $100.00
    Dec 09, 2009 | Kenmore Dryers
    Propane dryer. Can hear the heat kick on but dryer doesn't heat
    Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
    May 31, 2009 | Kenmore Dryers
    Dryers Logo
    46 people viewed this question
    Top Admiral Dryers Experts
    gbob59
    Sal De
    Are you an Admiral Dryer Expert? Answer questions, earn points and help others
