Question about Kenmore Oasis HE 27082 Top Load Washer
LAVADORA KENMORE ELITE OASIS MOD 110.28032701 CODGO DE ERRO F 51
SOURCE: lavadora kenmore HE3 parpadea la luz de delay cuando faltaba 15 minutos para terminar el ciclo.
necesito instrucciones de uso de mi lavadora kenmore Elite pero en español
Posted on Jul 10, 2009
  • 1937 Answers
SOURCE: F-51 code on kenmore elite oasis washer - how to
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Posted on Oct 20, 2009
larryyb
  • 291 Answers
SOURCE: kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Posted on Nov 25, 2008
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Lavadora kenmore osasis he, pierde agua por abajo
tengo un problema con mi lavadora kenmore elite oasis he q cuando la prendo me aparese un 60 y ah se queda ????
Feb 29, 2012 | Kenmore Oasis HE 27082 Top Load Washer
My top loader Kenmore Elite Oasis HE washer displays F 51 error ?? Any ideas and suggestions on how to fix this
F then 51 flashes when there is a motor rotor position sensor. Captain we have a problem? What is now Spock? More primal urges? Worse captain! Engines overheating. Spock can you pinpoint the source? Yes Captain: Abnormal activity within the wash water. What? Suds detected. Computer report. On board sensors have detected suds sir. They have made several attempts to clear up the situation by running extra rinse cycles!. As a result RPS has overheated causing engine failure. What will we do Spock? Capatin we need to See TEST #3, Page 10.
Apr 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
