Question about Microwave Ovens
Asian Fusion MultiCooker instruction manual - Microwave Ovens
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
How do you install a microwave above the stove
If it's a new oven, it will come with installation instructions.
If it's a used one, you would have to visit the manufacturer's support Web site to download installation instructions if they are available.
Wish you had mentioned your brand, at least.
You can download GE owner's manuals and installation instructions here.
You can download Maytag owner's manuals and installation instructions here.
You can download Frigidaire owner's manuals and installation instructions here.
You can download Whirlpool owner's manuals and installation instructions here.
For other brands, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
May 03, 2013 | Microwave Ovens
I'm trying to get a source for my Sunbeam Multicooker Oven Frying pan connector .It has packed up. I'm prepared to buy a new oven frying pan if I can find a source.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 15, 2011 | Sunbeam Microwave Ovens
When i close the door it blows the 13a fuse. If you open the door when microwaveing it blows the 13a fuse. The microswitches on the door sometimes weld. My previous r950a had all these same faults. How...
To cure this error, replace the door switches and realign the door, checking the door closers for contact and correct clearance. The usual cause of this problem is slamming the door or contamination of the switches.
Very nice reliable machines.
Dec 27, 2010 | Microwave Ovens
Frigidaire MIcrowave does not heat food and it makes a noise
The usual answer here is that the magnetron has failed and is trying to blow the fuse. This seems to be a common failure with Asian manufactured magnetrons. The cost of a typical repair may induce you to purchase a new machine. Hope this helps!
May 14, 2010 | Frigidaire FMV156EM Microwave Oven
Its runs but no heat.
It is usually the magnetron tube that fails which then blows an inner-cabinet fuse. The world seems full of bad Asian made magnetrons that fail prematurely due to air infiltrated internal vacuums from leaking metal to glass seals. It will probably cost more in parts and labor to repair than a new unit. A well made magnetron should gradually lose output power over time (years), not just quit. Hope this helps!
Apr 06, 2010 | GE XL1800 1100 Watts Microwave Oven
My whirlpool microwave model GH5184XPS4 has started making buzzing noises all throughout the day when it is not in use. It started doing it when I would cook something that created a lot of steam on the...
un-plug it, it is not safe. i am thinking that the transformer is making the noise, probably because of the moisture.(cheap asian electronics) it could catch on fire.
Jan 14, 2010 | Microwave Ovens
Intruction manual needed
Since the company seems to not even offer microwave ovens currently which, to me, is an indication that they are buying and having rebranded some Asian (Chinese or Korean) make and may not even have service information or support.
I checked a site you may not have found that often has info available, Retrevo.
You might want to visit and bookmark it in case they acquire what you need in the future;
http://www.retrevo.com
Jul 06, 2008 | DeLonghi Microwave Ovens
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
