Question about RCA HD50LPW175 50" HDTV
RCA HD50LPW175 Color Wheel Replacement
Thank you for the advise about the jumper on the DMD module. I have seen this advice for Samsung DLP sets in many places but nothing about the RCA sets. Are they the same?
  • 1153 Answers
SOURCE: rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Posted on Jan 08, 2008
Luvlee
  • 59 Answers
SOURCE: SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: how to replace the color wheel on a RCA DLP
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Posted on Jul 27, 2008
  • 74 Answers
SOURCE: DLP DMD board
BP96-00249A $937 at partsore.com i hope that isnt the problem
Posted on Sep 22, 2008
SOURCE: RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Posted on Jan 06, 2009
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
Blurry after Installing Colro Wheel?
Hi,since you are getting the new silver air pressure version you will need to put an jumper to the dmd board,why because gold version spins different than sliver and that will produce the tv to have color discoloration or bluryness.Good luck and God bless you!
Oct 06, 2009 | Samsung HLR5064W DLP Projection TV
My set is the SAMSUNG LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do n
The new color wheel is different from the original. The original used an Air Bearing type motor. But the replacement type is a standard bushing type motor. There is a jumper on the rear of the DMD board that may or may not be covered with a paper sticker. Reposition the jumper to accommodate the new color wheel.
May 21, 2009 | Samsung HLR5064W DLP Projection TV
Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Jan 22, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung HLP4663W color wheel replacement
yes its true grt your self a pair of needel nose pliers and pull that jumper.
I had a tv set in my shop for weeks till i lerend that one
wat it was is that the new color weel motors are air cor and spin faster that the originals, so pull the black jumper it looks like a small hard drive just remove it
your set will auto ajust.
ther are sum small settings to add in the service menue to fine tune it.
but first pull that jumper..
seting can be found on google... i think i found it on tech assist.
and enterd model number.
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
Changed samsung hlp6163 colorwheel now all the colors are off alot of blue
There is a place for a jumper on your DMD (the module that the color wheel plugs in to) If the jumper is there remove it. If there is no jumper install one. On later models the pins are gone but solder pads are still there, solder it. Some wheels have air bearing and others have fluid bearing. You really should buy a service manual for that set. New color wheels sometimes come with CCA values that you must change in the service menu
Good Luck
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Apr 09, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
RCA HD50LPW175 50" HDTV Logo
355 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
