Question about GE JTP20 Electric Single Oven
Oven heats very slow
How do i trouble shoot electric elements?
    Problem Solver:
Get a multimeter and test the resistance of the element and ohms, be sure to turn off the power first, take the element loose, and ohm it out, and check the resistance of the element. Most multimeters have a continuity setting, and try that and see if the element has continuity. if it doesnt, chances are that that is your bad element
Posted on Jan 23, 2009
Oven not heating!
Hi Michelle,
I understand you are having trouble with your oven not heating. Based on the little bit of information provided I could suggest the following. If you are having problems with the individual bake or broil then it is likely that the single element is the problem. However, if you find that neither element is heating then electrical connection could be causing the oven to not heat.
Best Regards,
Jan 22, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Ge p7 electric wall oven
replace heating element its breaking down
Nov 28, 2013 | Ovens
Oven heating really slow
yes it sounds as if there is a "HOT-SPOT" on the element which will look like a dis colored spot and will be either bubbled up or have pock marks where its burning thru and can no longer pass sufficient current to heat the element fully
Apr 04, 2010 | Maytag 30 in. Electric Single Wall Oven...
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
We've a Whirlpool Gold Accubake System (electric). Yesterday, the oven was working fine, we did a cleaning and today when we went to use it and it would not heat up. Is there a way to determine if the...
its not uncommon to have this happen. it may have overheated . causing the hi limit on the back of oven to fail, that is what you need to ck . and repl if you find it to be bad. **** .. if your want to ck the element then when the back is off range . you can ck the two elem with a ohm meter . . ****
Dec 25, 2009 | Ovens
Oven heating up slow
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 23, 2009 | GE Profile JTP18 Electric Single Oven
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Apr 15, 2008 | Frigidaire PLEB30T8A Electric Double Oven
GE JTP20 Electric Single Oven Logo
137 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
