Question about Home
The pump on my maax aerosens tub starts on its own
4 Suggested Answers
  • 659 Answers
SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Posted on Aug 19, 2009
  • 123 Answers
SOURCE: Hi, We purchased a Maax 10 jet Whirlpool tub
http://www.maax.com/Upload/guides/fr/000_10050073_0305.pdf.......this should take care of what you need. If you have any questions just ask.
Thx
Ken
Posted on Sep 08, 2009
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I cannot...
The drain may have been installed incorrectly. It should not be that easy to "pop" open. In normal operation, you push it down until it latches in the closed position. Afterwards, you push it down to unlatch it and start draining.
Feb 08, 2015 | Maax Plumbing
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 | Maax Home
Bought a used maax hydrotherapy airotherapyand chromotherapy tub. I hooked everything up and I don't get the light to come up for the whirlpool function and thus can't get the pump for the airotherapy to...
Start with the simple things first. Remove the bulbs for the chromotherapy lights and look for any corrosion that may be inhibiting the lights from working. It sounds like you may have purchased a tub that needs a refit or overhaul. Your best bet is to spend the money and hire a licensed electrician to examine the unit. It's best to be on the safe side when dealing with water and electricity. For safety the tub should be on its own ground fault interrupted circuit. GFIC.
Jul 12, 2010 | Maax Home
E06 error--how do you get rid of flashing this error and what causes it in the first place. Thanks
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Feb 10, 2010 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Thx
Ken
Aug 12, 2009 | Home
Error e006 maax tub water level sensor
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
May 09, 2009 | Maax Calla 6042 Bathtub - 101058-000
Find board for maax bubble-tub
Mar 22, 2009 | Maax Home
Home Logo
64 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
