Question about D-Link Computers & Internet
Connect dlink dir826l usb printer - D-Link Computers & Internet
How can i networked my kyocera taskalfa 180
You only have a usb 2 connection.
You can hook it to one p.c and share out the printer to other p.c.s.
You could invest in a router that has provision for sharing out a usb printer connected to it.
You could invest in a USB printer server. see http://www.dlink.com/us/en/home-solutions/connect/print-servers/dp-301u-10-100-ethernet-usb-print-server. However you need a ethernet network already in place with your other computers. You can connect your other p.c's via ethernet and use a network switch device to connect all devices to one another if you do not have a network or use a wireless Router and wireless adpaters or p.c's but no more than 4 p.cs on wireless.
Aug 31, 2014 | Kyocera Office Equipment & Supplies
How to connect my lexmark pro205 printer to a dlink 655 router?
Run the installer again. It will ask you if you want to connect your printer using a USB cable/Ethernet/Wireless. Choose wireless and follow the steps.
Nov 11, 2012 | Lexmark Prospect Pro205 Wireless...
How to connect my printer to a dlink 655 router
It would be best to reinstall the software of your printer. When installing the software, it will ask you if you want to connect your printer using USB or wireless, choose wireless and follow the prompts.
Nov 11, 2012 | Lexmark 90t6005 Prospect Pro205 All-in-one...
I have ATT internet service using a USB device( no DSL or cable wires/lines, just plug in the USB into the port, that's it). I also have a wireless printer that is setup with a DLink router. When I print...
In order for you to print on that particular printer, your computer and the printer need to be on the same network. That is the only way it will work. So, either connect your computer to that Dlink router or connect your printer directly to your computer and browse internet from USB ATT.
Hope this helps.
Aug 11, 2010 | Computers & Internet
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
How do i add the printer the dlink dir 628 router
The DIR-628 does support a USB printer. You need to download the appropriate shareport version from dlink http://www.dlink.ca/products/?pid=DIR-628&tab=3.firmware
If the printer drivers are already installed on your PC you should be ready to go.
Sep 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Print server configuration in canon mf4150
I had the same problem. After many hours of trial and error, I got two XP laptops and a Vista desktops configured. Be sure to use the latest firmware from Dlink. Disable all s/w firewalls. In my case Norton Firewall from Yahoo was a problem. The Vista PC was configured to print within 30 mins and the XPs took a while. I couldn't get the print server to appear in the My Network Places A couple of the guys who left comments on the product at Newegg actually have a good solution. The solution involves setting the printers up as local printers with standard TCP/IP ports that point to the IP address or the URL ("dlink-"6_last_digits_of_MAC_ID) and USB port number 9100-9103. You can google how to set up local printers w/ TCP/IP connections with USB ports on the internet. Note the Scanner will not be recognized but at least you can print on MF4150.
Dec 12, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
Computers & Internet Logo
122 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
