Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
I have a Sta-Rite model number PE 5L 125L 3/4 hp pool pump that is squeaking..need new bearing I think..any way I am trying to remove the face of the pump housing. I have removed the 4 large bolts that hold it on but now I can move it back and forth a bit but it won't come off. Is there a clip or screw holding the pump face on the motor or a key, bolt?? There doesn't seem to anything I can remove to get at the end of motor shaft to see if there is something there holding it on..so what should I do to get it off..this link ( http://www.pentairpool.com/products/replacement_list.php?id=103 ) has a pic of my pump or one very similar and I have #'s 3,7 and 8 that are all together I can take 8 off but it doesn't seem to get me to anything removable..
  • rbgerons Jan 23, 2009
    You to hold the other end of the shaft in place and then the impeller screws off.
    Problem Solver:
  • 11 Answers
Their should be a screw holding the impeller(#7) in place. If it is like the older models, you need to turn it clockwise to remove it. Once you get that screw out, the impeller should come out. They do tend to get stuck sometimes, and you may really have to pry it off.
Posted on Feb 14, 2009
  • 547 Answers
There is a 'c' clamp at the other end
Posted on Feb 12, 2009
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta rite pump
no bearings available need new motor
May 01, 2013 | Hayward 1 Hp 2 Speed Super Pump Inground...
My sta rite pool pump motor is squealing
you can try new bearings but its best left to a pro electric motor rebuilder, check your area for pool pump motor repair with free testing
Aug 08, 2012 | Sta Rite Pool & Spa
I have a older spa with a Sta Rite pump motor. Without removing the damaged pump I was able to see the model number of the pump through a mirror. I beleive it reads K48M5A3, is there any way that you can...
That would definitely be the model number. The K indicates Capacitor start and run, the 48 indicates the frame size, and the "M" indicates horsepower (1.5 hp, in your case). If your replacing the motor, make sure you get the same Horsepower and Service Factor ratings. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 12, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a sta rite abg series pool pump, u can see my pump at this link: http://www.poolpartsonline.com/p-59481-sta-rite-abg-series-pool-pump-parts.aspx My motor is making a high pitched sound and i was...
It will be better to service the machine the machine than to change the bearing.
Servicing the machine will stop the high pitch sound and makes it work better and also reduce your cost.
Thanks for contacting Fixya.
Jun 30, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
sounds like you have not unthreaded the impeller off the shaft of the motor. it unthreads counter clockwise.
Jan 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Tring to take the pump face off the motot
at the back there should be a 'c' clamp remove the 'c' clamp and the whole shaft should pull out.
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
155 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
