Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
Tring to take the pump face off the motor
I have a Sta-Rite model number PE 5L 125L 3/4 hp pool pump that is squeaking..need new bearing I think..any way I am trying to remove the face of the pump housing. I have removed the 4 large bolts that hold it on but now I can move it back and forth a bit but it won't come off. Is there a clip or screw holding the pump face on the motor or a key, bolt?? There doesn't seem to anything I can remove to get at the end of motor shaft to see if there is something there holding it on..so what should I do to get it off..this link ( http://www.pentairpool.com/products/replacement_list.php?id=103 ) has a pic of my pump or one very similar and I have #'s 3,7 and 8 that are all together I can take 8 off but it doesn't seem to get me to anything removable..
sorry about the double posting but I had wrong email on the first one
  • 125 Answers
Sounds like you have not unthreaded the impeller off the shaft of the motor. it unthreads counter clockwise.
Posted on Feb 26, 2009
Sta rite pump
no bearings available need new motor
May 01, 2013 | Hayward 1 Hp 2 Speed Super Pump Inground...
My sta rite pool pump motor is squealing
you can try new bearings but its best left to a pro electric motor rebuilder, check your area for pool pump motor repair with free testing
Aug 08, 2012 | Sta Rite Pool & Spa
Procedure to change electric motor on sta rite pump
better off to replace whole pump if motor overheating seals going bad too if leaking soon bad bearings
Jan 16, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I have a older spa with a Sta Rite pump motor. Without removing the damaged pump I was able to see the model number of the pump through a mirror. I beleive it reads K48M5A3, is there any way that you can...
That would definitely be the model number. The K indicates Capacitor start and run, the 48 indicates the frame size, and the "M" indicates horsepower (1.5 hp, in your case). If your replacing the motor, make sure you get the same Horsepower and Service Factor ratings. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 12, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a sta rite abg series pool pump, u can see my pump at this link: http://www.poolpartsonline.com/p-59481-sta-rite-abg-series-pool-pump-parts.aspx My motor is making a high pitched sound and i was...
It will be better to service the machine the machine than to change the bearing.
Servicing the machine will stop the high pitch sound and makes it work better and also reduce your cost.
Thanks for contacting Fixya.
Jun 30, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Pump Very Noisy Have dismantled moving parts and no difference so deduced that it must be electric motor, how do I replace brushes?
sounds like you need to replace the bearings. You may be better off either taking the motor to be rebuilt or getting a new motor with a warranty. It is a process to replace the bearings if you have never done it before.
Feb 21, 2010 | Sta Rite Sta - Rite 3/4hp Dura - Glas...
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Tring to take the pump face off the motot
at the back there should be a 'c' clamp remove the 'c' clamp and the whole shaft should pull out.
Jan 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
200 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
