Check Fan 1 is on screen. series 7 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Cooling fans should be checked.
Posted on Jan 14, 2013
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
Have Lexmark 1200 series want to install on Windows 7 should I download drivers first amd then try and install software or the other way around?
Please follow the steps below on how to properly install your Lexmark 1200 Series printer on your Windows 7:
1. Check the version of your operating system. Go to Start menu > right-click on Computer and choose Properties to see if you have a 64-bit or 32-bit OS.
2. Visit the Lexmark website to download and install the printer driver on your computer. Use the links below: - Lexmark X1200 Series Driver for Microsoft Windows 7 32-bit - Lexmark X1200 Series Driver for Microsoft Windows 7 64-bit
3. Follow the instructions on your computer screen. The software will show you a step-by-step instructions on how to setup the printer as well.
Oct 09, 2011 | Lexmark X1270 All-In-One InkJet Printer
Error message check fan 1 on my samsung 7 series lcd tv
remove back cover and clean fan with q tip and alcohol also vacuum all around do not use compressed air to blow on it
Sep 03, 2011 | Samsung LN40A650A LCD TV
How to change the fan belt in my 1988 BMW 735i
The alternator and water pump share the same belt. You will have to remove all three as the fan/alternator belt is in the back. The alternator and AC compressor both have bolts which you need to loosen to get them to swing forward and release tension. Make sure you rotate onlt the backside bolts. The frontside bolts on the brackets have teeth which are used to increase tension. If you turn those, you will strip the brackets and have to buy new ones. The link below gives you the proper sizes.
http://forums.roadfly.com/forums/bmw/bmw-7-series-e32/4688310-1.html
Aug 14, 2010 | 1992 BMW 7 Series
Need Fuse Map Diagram BMW 318i 1993
check the internet for a bmw e36 ETM ( electronic troubleshooting manual) everything you need is there.
Jun 02, 2009 | 1994 BMW 3 Series
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Printing problem
hi,
You need to reinstall the printer driver.
First check which operating system is used with your product? After that download the software from Download  Full Feature Software and Drivers.
How to Uninstall the printer Software :-
Follow the steps below to remove the hp LaserJet 1020 series software from the computer:
  1. Disconnect the USB cable from the computer.
  2. For the Windows Desktop, click Start , click Programs or All Programs , and then clickhp LaserJet xxxx series .
  3. Click Uninstall hp LaserJet xxxx series .
  4. Follow the messages on the screen to remove the software.
  5. Reboot the computer when instructed.
OR
2. For the Windows Desktop, click Start , click Crontrol panel, select add\remove(XP) or program future (VISTA).
 After restart install the printer driver and follow the screen instructed.
Sep 02, 2008 | HP LaserJet 1022 Printer
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
