Question about Toshiba DRW2 DVD Recorder
Lost remote for d-rw2su recorder cant seem to get it to read or record discs now is there a way i can get it to work without the remote?
Lost remote .cant get the player to read or record discs is there a way I can get it to do that without the remote or will I have to get one? The AT&T u verse one I have programed works great for everything else on it, but it don't have the set up button that gets me into the disc setup menu. Any help would be great. I cant believe they don't have a manual way of doing it.
Ajkill
  • 2035 Answers
SOURCE: remote control code
The remote control for your DVR has the capability to control 2 additional DVRs in addition to the one that you currently have. In order for the remote control to work with your DVR, you will need to make certain both of them are talking on the same frequency. If you press the remote control and the front of your unit says DR2, that means that you need to have your remote on DR2 as well so that it can operate the DVR. To set your remote to DR2, you will need to make sure the unit is off then you will need to press and hold down the SETUP button and while you are holding this button down, press the number 2 button. Your remote is now set to DR2.
Good luck...
Posted on Sep 07, 2008
SOURCE: get message "incorrect disc"
One thing you can try and do is unplug the unit for 3 min and then attempt the dvds again
Posted on Nov 04, 2008
  • 89 Answers
SOURCE: disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Posted on Jul 28, 2009
SOURCE: HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
michaelz@resourceinternational.com
Posted on Aug 05, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: how to finalize a recorded dvd disc?
on the remote is there quick navi button (this will take u to the finalizing screen)
Posted on Jun 26, 2010
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Changing region code to play all dvd's
You can find a work around from this website
http://www.dvdchips.co.uk/
Solderless upgrade for R2 Panasonic DMR-E75.
This custom manufactured version of our Chipped Remote will convert Panasonic DVD recorders to Multiregion without removing the cover. A disc will also be supplied and MUST BE USED BEFORE THE REMOTE !
newcustomremote.jpg This remote and disc will upgrade one recorder only. Orders will be taken via Credit or Debit Card at the price of £20.00 including shipping, please read our Remote Recycling Policy HERE.
Please read the instructions below before ordering, you may need to download acrobat reader to view them. Instructions for the disc will be supplied with it. THE DISC MUST BE USED BEFORE THE REMOTE !
Mar 26, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have lost my remote on my Panasonic model DMR-E85HEP. How can I finalize a recorded DVD manually?
Sorry, but you can't perform this function without the remote for this model. ('finalise disc' is likely to be part of the DVD management menu - thus the remote is required to access this)
Mar 30, 2011 | Panasonic DMR-E85H DVD Recorder
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Im actually ona magnzvox zc350ms8
use the set up button on your remote. Which brings you to the set up menu. Go to the very last option which is disc edit. then a new menu will come up and go to finalize disc, then a new menu pops up and just select yes. You have to have your remote to do this.....so make sure you hold on to it!!!!
Jun 18, 2008 | Philips Magnavox MWR10D6 DVD Recorder
TOSHIBA RDXV45KB
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
Mar 22, 2008 | Televison & Video
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Toshiba DRW2 DVD Recorder Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
