Question about RCA RCRN04GR Remote Control
Code for a samsung sound bar - RCA RCRN04GR Remote Control
How do I change the volume of my sound bar using the harmony 650? Right now the volume button only changes the volume of the TV. I have an LG tv and a Samsung sound bar connected by blue tooth. Thanks
You have to program the remote for the sound bar then only you will be able to control use it wit sound bar.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Samsung Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Jan 01, 2015 | Sanyo Televison & Video
I need a remote control code for rc65 direct tv remote to control samsung hw-f350 sound bar
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 07, 2014 | Directv RC65X Universal Remote
How can I resolve this?
Hi Gary
This can happen infrequently due to either the iPad needing a restart (iPhone 5's and 5s's) have similar issues.
There are two things to try;
1) Turn your samsung sound bar off, and pull out the power cord out of the wall, now this may sound unnecessary but the logic behind that is to have it clear any potential "error code" or crashed script which is powering the bluetooth transmitter in the sound bar. You do this for ca. 60 seconds, 30 will do too but we just want to be sure. Once that is done plug the bar in again and power it on and see if it works now.
2) Restart your iPad, this has the same logic behind as step one, but in this situation i'd like you to turn both off starting with your iPad.
It is not uncommon especially depending on the iOS your running on your iPad for the bluetooth transmitter not to see the bluetooth sources around you.
To turn your ipad off push the sleep/power button at the top right of your ipad for 10-15 seconds. Until you see the swipe to turn off. Let it shut down completely after you swiped it to turn off. (this can take a minute) Once you see the spinning wheel on your ipad disappear start with unplugging your Samsung Sound Bar. As in step one follow the same procedure until its back on. Now turn your iPad back on with the sleep / power button and wait till its fully loaded.
Now in the settings>bluetooth you should in theory see your sound bar again. If you still encounter problems don't hesitate to let me know.
Have a great weekend
Philipp
May 05, 2014 | Samsung HW-E550 Crystal Surround Air Track...
Connecting sharp tv to samsung sound bar
don't you mean sound bar to tv?
your tv has an input and output for audio and video,find the audio output and connect the sound bar!
Jan 07, 2014 | Samsung HW-D450 Sound Bar
Need a code for the Samsung Sound Bar model HW-C450 with the Time Warner CLIKR-5 remote model URSU-8780L-TWK
I need the codes for my samsung sound bar system using timewarner remote in san diego.
Dec 24, 2010 | Televison & Video
RCA RCRN04GR Remote Control Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
