Question about iRiver iHP-140 MP3 Player
Did I fry my player or can it be fixed
Fumbling in the dark I plugged the wrong adapter into my player while it was on. It froze and began to get hot. Now it doesn't boot up at all. Please help my beloved iRiver back to life. Thanks in advance...
  • David Slominski Jul 08, 2007
    When I plug in the power adapter it appears to charge normally (lights green then turns off when charged). Should the unit boot up with the power adapter connected, even if the battery is bad? It doesn't currently, but maybe that would eliminate a battery issue.
    Thanks
  • 3 Answers
There is a thread on fried players with a fair bit of information on components likely to be damaged and the repair of the players over at misticriver.net http://www.misticriver.net/showthread.php?t=44799 if your handy with a soldering iron .
Posted on Sep 27, 2007
    Problem Solver:
  • 12 Answers
Open the player and test for battery's voltage. In case of a low voltage measurement,you should replace the battery.I don't want to be cruel with you but, maybe that the player power circuit was damaged as well,and in this case it should be repaired by a certified technician (I realy hope for you that this is not the situation). Good luck !!!
Posted on Jul 08, 2007
Wrong a/c adapter fried a component dont know how to fix without sending it off (dont want to) any suggestions?
It is possible that you have connected an adapter with a higer voltage or one with a wrong Polarity. In both the cases it is possible that the front end of the player has damaged components.
In some cases there is a possibility of the ZENER which is the protection in the input circuit that could have burned and saved the cicuit as it is normally connected to protect in parallel.
SO you need to check this out , also the short can burn up a fusible resistor or fuse and so could save the circuit. Use a mulimeter to check this section of the circuit. If not there will be serious damage on the main board.
Jul 13, 2011 | Numark Axis 4 CD Player
Fried unit, european plug
Pls check fuse of ur Cdj's
djajay
Apr 13, 2010 | Pioneer CDJ-800 Turntable
I plugged the wrong charger in and I think I fried my battery. It won't work ever since I plugged it into the wrong charger. What is the easy way to fix it?
the best way to fix your issue is to replace your mp3 player batteries. you can do this by contacting the shop from where you purchased this player.
Dec 08, 2009 | iRiver iHP-140 MP3 Player
DSR-1500 firewire port doesn't work. Any
It may be that the firewire cable has been inserted the wrong way round. Unfortunately this is a common problem as it is quite easy to do this especially when fumbling around with limited access behind the deck. Worst case scenario is that the Firewire circuit board has been fried! Firewire connection carries 30 volts, and if this connect to the wrong pins - pop goes the board. It's a £300 job to fix (I think). But first of all try pairing down any patching / connection to other equipement to a minimum to ensure that there is not something else in the chain that could be causing the problem.
Oct 06, 2009 | Sony DSR-1500 Mini DV VCR
Toshiba A-135 laptop froze up, dark screen, will not boot
Try this -
1. Remove any USB devices such as ipod, printers etc etc
2. Remove the ac adapter and the battery
3. Press and hold the power button for 30 seconds.
4. Put the ac adapter back in but not the battery
5. Dont plug in any other devices and turn the computer on.
Jan 19, 2009 | Computers & Internet
Charging player/downloading songs causes computer to crash.
You can purchase a "AC to USB" power adapter for about $30
Mar 04, 2008 | RCA OPAL M4001 MP3 Player
Iriver h320 freak out!
I have the same problem and Iriver told me the hard drive is shot.
Unfortunately they will not / can not fix it as they have no "out of warranty repair," nor do they have anyone who will do this for them.
Mar 03, 2008 | iRiver H320 MP3 Player
My insignia pilot froze
Hold the power button for a while. Then it'll turn off.
Dec 27, 2007 | Audio Players & Recorders
iRiver iHP-140 MP3 Player Logo
110 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
