Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Remove Intermatic 60 min. wall timer face plate only from wall
The Intermatic face plate seems bigger than the cover plate. Does the knob come off in order to only remove the face place? I want to paint the wall behind it.
  • 37 Answers
That knob should just pull straight off. Check to make sure there isn't a tiny set screw on the side, but otherwise you can pull it off and remove the cover plate.
Posted on Jan 24, 2009
How to remove a Intermatic 30 Minute Spring Wound Timer FF30MC
10-22-12
FF30 Intermatic timer: The turning knob pulls off.
(With some really old models, 1960s, there is a small set screw on the fat end of knob.)
Under the knob is a small hex nut that twists off to remove plate.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/How-to-wire-switches.html#gang
Oct 22, 2012 | Spring Step Intermatic 30 Minute Spring...
I cant get the older (10 yrs) timer out to see if my junction box will hold a newer digital model. I tried to pull the knob out but it doesnt budge. There doesnt seem to be a set screw.
If following information does not apply, then add a comment with in-focus photo of timer posted on flickr, for possible help.
All timers are attached to electrical box with 2 screws that are usually hidden by a cover plate.
Some really old timers have a set screw on the knob itself.
Most 'knob' timers fit onto a shaft by friction. Put a pry bar under it and force it off.
If timer is attached to cover plate, see if you can break the cover plate.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Need to be able to disassemble an intermatich FD2HW - take the plate off the wall to paint the wall. Not sure if the timer buttom pops off or unscrews to remove it? Not like my other light switches which...
The knob pulls off.
Use small screwdriver to pry it up.
Really old FD and FF series timers, the knob has tiny set screw in end of knob.
I haven't seen one with set screw for years
Dec 25, 2010 | Intermatic FD2HW Energy Controls - In-Wall...
HOW DO YOU REMOVE THE KNOB FROM THE 15 MINUTE INTERMATIC TIMER SWITCH SO YOU CAN REMOVE THE SWITCH PLATE.
The knob pulls off.
Use a screwdriver or fingernail file to pry up.
Some really old timers, the knob attaches with a tiny screw located on the knob.
Dec 23, 2010 | Intermatic Spring Wound Wall Switch Timer
10 year old timer will not shut off any more
It's broken.
I have a FF series countdown timer on a water heater circuit that's been used for past 4 years.
The FF and FD series timers are heavy duty, spring-wound countdown timers.
I expect 10 years is a good lifespan.
You can buy a new spring-wound countdown timer at Home Depot or Lowes, but new ones are lighter weight than the good ol' Intermatic.
Grainger sells the FF60 (60 minute, metal cover)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-6X546?Pid=search
Grainger shows the FD60 (60 minute, plastic)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-1XC27?Pid=search
Grainger Intermatic timers shows a lot of FF and FD timer choices:
http://www.grainger.com/Grainger/intermatic/ecatalog/N-1z0r56r
There are several pages of Intermatic timers:
FF5minute thru FF12hour
FD15minute thru FD60minute
Nov 09, 2010 | Intermatic FF12HHC Energy Controls -...
I need to replace the timer. How do I get it off? There are no screws on the cover plate and the knob does not pull off. I can not find a way to remove the fixture??
The plate is held by a nut that is located under the knob.
Pull the knob back and it slides off, and you can see a small 8-sided hex nut.
The nut is a bit hard to grab, but you can wrestle it off with a pair of ordinary pliers.
Oct 20, 2010 | Intermatic FF12HH Spring Wound Timer
How do I remove the knob so I can remove the back plate without breaking anything?
Most of these wil just pull off, but some has a small set screw on the knob.
Sep 06, 2010 | Intermatic Spring Wound Wall Switch Timer
I need to remove the intermatic switch from my wall.
If this timer has one knob, there should be two removable pins put one pin into the time you want to start and put the other pin in the time you want it to stop. Then set to current time
Jul 27, 2009 | Hardware & Accessories
How do i remove it from my wall
simple remove the plate then there are two screws that you need to unscrew then you pull the whole thing out.
Jul 12, 2009 | Intermatic Hardware & Accessories
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
2,420 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
