Question about Goodman CLQ36AR49 Air Conditioner
Goodman Heat Pump freezing up
I have a new 31/2 ton Heat pump, it freezes up at night when the temp is under 30deg. I was wondering what should the defrost timer be on 30 60 or 90. I am trying to find the right setting so it won't over defrost, if that is possible. and during defrost cycle I've noticed the outside fan continues to run, is this normal? I don't know what the timer is set on now ( Factory Settings). The installer says the freezing is normal. Everything else seems to be working, my bills are higher than the old unit that was over 25 yrs old. Can anyone help with some advise. Ice cube in Tennessee
    Scholar:
  • 144 Answers
In your climate usually the defrost timer would be on 90. However if you are in an upper elevation and it gets colder then set it at 60. what model unit do you have? Did they change both indoor and outdoor units? I would have to know the model # to tell if the fan should run in defrost. In most cases I would say no.
Posted on Jan 23, 2009
    President:
  • 1,214 Answers
Sounds like it is not going into defrost if the fan runs during defrost.
Ice/frost buildup can occur, but if the unit becomes a solid mass of ice, then there is a problem in the defrost circuit. Could be the defrost sensor as well, which is a little round metal can with 2 wires in it attached to the refrigerant tube inside of the condenser. But your serviceman is right, some frost is normal.
Defrost time setting is somewhat subject to where you live.
    Sergeant:
  • 311 Answers
On all the units i worked with out a defrost system if it frosted up it was because its running to long and may be was too small for the area tiring to cool.it could also be low on charge and so can't cool efficiently.that may be possible if its a new system. ive had customers that had gotten a new system from a HVAC company and it didn't do the job and they told the company to come and get it and put the old one back.and they did.whats the use of a new if it cost you more money to run.i think your HVAC company dosen't know whats going on.you may want another opinion
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
Package unit tubes freezing up after metering device
check refrigerant charge. A low charge with cause what you are experiencing.
Jun 30, 2014 | Goodman Manufacturing Goodman GPH1342M41...
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
I have a leak
Under warranty from 10 years ago??
I would get it repaired properly by a qualified service engineer after speaking to the manufacturer.
Nov 16, 2017 | Goodman GPH1536M41 3 Ton 15 SEER...
I have a goodman self contained heat pump that is 3 and 1/2 years old. I wake in the night to hear what sounds like the fan runnning and running and running and air moving thru the vents. Then I will hear...
Heat pumps are a very efficient design when working properly. But lose efficiency the colder it gets outdoors. I usually tell people when it drops below freezing to turn the thermostat to aux or em. heat. A heat pump can remove heat from 20°f air. But not very well. More heat at 30°f air, obviously, and so on. So the colder it is outdoors, the longer it will operate to remove heat from outdoors. And then, if it can't keep up, it brings on the electric heat elements to compensate. Now you are running both outdoor and indoor heat. This is where it's inefficient and costly. Also, the outdoor will start to freeze up. This is normal unless you can see a substantial amount of ice. The heat pump will engage defrost mode, cycling on the electric heat indoors. And defrost mode is actually cooling mode! The reversing valve in the heat pump switches to cooling mode, cycles off the outdoor fan, and defrosts for a set time or temp. So now your electric heat is engaged, and your indoor coil is a COLD coil! Not hot! Very inefficient. These 2 things are why your elec bill is higher in the winter. So it makes sense to me, if the elec heat is going to be on anyway, to move the tstat to aux or em. heat, when it's going to be below freezing outdoors. This will turn off the heat pump and use elected heat only. The only down side to this is, if you don't have enough elec heat to keep you warm, you may need both heat pump and elec heat. So trial end error until you find what works. Also, have a qualified tech check the system for operation and efficiency. Hope this helps!
Apr 08, 2017 | Goodman PHKJ048-1 Air Conditioner
My 4 ton goodman heat pump goes into defrost and than after the cycle return in cooling stage at least the indoor coil starts freezing is the expansion valve working corectly
The reason for indoor coil freezing due to coil dust blocked-(Clean coil). 2. Less rpm of indoor f.motor. (Replace capacitor). 3. Short of gas. (Find leak and repair and then recharge gas.)
Jan 04, 2011 | Heating & Cooling
I have 4 ton carrier heat pump / puron. It is a new system been installed about 3 months. Live near Dallas Texas and lately the temp has dropped into the low 40's at night. The heat seems too be working...
The water is from humidity in the outdoor air which has condensed and then frozen to your heat pump outdoor coil. The heat pump will defrost occassionally, depending on how much frost has accumulated to the coil and will then generally drip off the unit and onto the ground. This is normal. To keep the water off the drive way may mean having to move the heat pump to a place where the condensation can run away from the drive area. Or provide some other means of redirecting the water.
Nov 20, 2010 | Heating & Cooling
I have a 3 ton goodman heat pump warm air is delivered from all the vents except for two which blows cool to cold air . help me , freezing im both bedrooms
if these are the longest runs from the air handler this can sometimes happen ,about the easest solution is to install a in duct heater into the duct feeding the rooms this is basically a set of electric coils installed in duct to re-heat the air going to the bed room
Jan 08, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
1,108 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
