Question about Oster 5838 ExpressBake Bread Maker
Shorting out about 2 hours into a 3 hour breadmaking cycle the machine is shorting out -- upon inspection of the coil -- i see 2 spots on the coil that are making burn marks on the inside casing --- I probably need a new coil -- is it worth the replacement of the coil? and if so, where would I get one to fit -- I have looked for parts and only see belts and paddle replacements
  • m606walsh Jan 28, 2009
    thank you for the suggestions , the pan had some burn marks that went thru the surface so I have ordered a new Breadmaker and will use the old one for parts --- thank you for a complete and thorough answer -- it was greatly appreciated.
  • 368 Answers
Hello m606walsh,
From what you've said, it sounds like the coil is expanding due to heat (or perhaps other stresses, can't tell without looking) and getting too close to the inside case, resulting in scorch marks.
You may not need a new coil - - try adjusting the one you have so it's not so close to the case. Since you didn't say so, I'm presuming that the case isn't so badly scorched that it needs replacement as well.
I'm not finding a heat coil in my usual list of spare-parts sources either, so finding genuine OEM parts may not be an option, but here are the three possible fixes that seem reasonable.
1) Contact Oster - - the Breadmaker 800# is 800-438-0935 - - and ask about their recommendations for parts or repair. They will likely not want you doing electrical repairs yourself, and will probably refer you to a service center.
Here's the URL for their Service Center Finder page:
http://www.oster.com/CustService.aspx?content=center
2) Consider buying either
- a used machine for parts (I'd start by hunting on eBay or other online auction sites like PropertyRoom.com
- a new machine and use your old one for parts (aka cannibalism).
I've used this strategy on both cars and computers - - often makes more sense than trying to hunt a spare part when you need it.
3) (I don't really recommend this unless you want to make this a hobby/quest) Pull the part and start visiting local appliance repair shops to see if it's an "off-the-shelf" standard OEM part. This can easily take more time than it's worth - - new breadmakers of this model are going for ~$70-$80 (plus shipping) on eBay and other online sources.
If I can be of further assistance, let me know.
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 28, 2009
  • Jon Stignani
    Jon Stignani Feb 07, 2009
    If you wouldn't mind, what I should have included in my "complete and thorough answer" to have earned a "FixYa" rating? "Thanks for trying" is for when I offer advice that didn't really cut it (which I try to avoid doing).
    I don't want to seem snobby or ungrateful; rather, my goal with each solution I provide is to earn that rating, and I care if my solution was in some way deficient.
    FYI - to maintain my "Expert" rating with FixYa.com, I'm expected to
    provide at least 30 free fixes monthly, and keep an adequate percentage
    of satisfied responses - - I need to provide answers that are accurate,
    complete and effective.
    Thanks in advance for your response.
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Welbilt bread machine kneading wont start.making ticking sound
some bread machines warm the ingredients before any mixing starts. If your breamachine doesn't start mixing within 1/2 hour then you DO have a problem. Give it a half hour before you assume it is broken.
Dec 10, 2013 | Welbilt ABM3500 Bread Maker
Dishwasher takes 3 hours to run through programme
3 hours isn't "extremely" long. If you run a normal cycle, it should run about 2-2:30 hours normally with the drying cycle. Now if it's over 3 hours, that would be a problem. Make sure that when you open the door that there is a lot of steam coming out, because that is the only thing that can extend the cycle is if the dishwasher isn't heating the water. Unfortunately this is a very common issue and it means that your control board inside the door has failed. There is a relay on the board that shorts out. This relay sends power to the heater, so when it fails the dishwasher doesn't wash well and it will run forever trying to heat the water which will never happen.
Sep 10, 2013 | Bosch Dishwashers
Use wooworths elevation breadmaker
A bread machine that works correctly goes through these basic cycles. If your machine did not do this then it is broken and you need to replace it. The cycles are, Mix.....Rise....Mix......Rise....very short Mix of a few seconds....final rise of over 1/2 hour......bake of approximately one hour......I sell good used machines that will come with a full money back 30 dayguarantee (shipping, everything) You can reach me at daryl441@msn.com or my website breadmachineshelp.com
Jul 02, 2013 | Kitchen Appliances - Others
Dough Will Not Rise
No, you shouldn't have to do anything special to it. There is something wrong with your recipe, ingredients, or your machine. Have you baked in your machine before and had success or is this your first try? Unless you are doing a rapid bread cycle. The full program will take 3- 4 hours. If I were you I would let it run and see if it turns out OK. 100 % whole wheat is going to be smaller than white bread.
Oct 19, 2011 | Kitchen Appliances - Others
Looking for recipe for rapid rise white bread
Rapid Cycle White Bread
  • 1-2/3 cups warm tap water
  • 2 tablespoon vegetable oil
  • 4-1/2 cups bread flour or regular white flour
  • 2 tablespoons dry milk powder
  • 1-1/2 teaspoons salt
  • 2 tablespoons sugar
  • 2 teaspoons bread machine yeast
Measure the ingredients into the bread pan in the order listed. Make a well in the flour and sprinkle the yeast into it. Set the machine to it's Rapid or Quick Cycle. On my machine this lasts for 80 minutes, or 1 1/3 hours. Press Start, and let the machine work it's magic. Remove the cooked bread from the pan after baking and allow it to cool before slicing.
Jan 20, 2011 | Black & Decker Bread Machine
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My Regal 6725 kneading blade does not turn when the machine is started. What can I do?
Some machines take a few minutes to start turning if the interior temp is too cold. Some always have a delay on whole wheat cycles. If it doesn't start kneading after 1/2 an hour then there is a problem. Let me know if it doesn't start kneading after about 1/2 hour.
Nov 07, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
The washing cycle takes 2 hours to complete
Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Need help with timer
The timer's lowest setting is the time it takes for the cycle (depending on which cycle u choose) to finish. If your machine has the ultra fast cycle, then you'd be able to make a regular white bread in an hour. else, you'll have to settle for the minimum of 3 hours to make a bread.
Here is the link to two manuals that have the same recipes. Hope this helps.
http://www.biscuitsbytes.com/manuals.htm
Mar 25, 2008 | Welbilt ABM3500 Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
90 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
