Question about LG 55LE5500 55 in. HDTV LED
Master reset lg 55le5500
The tv will turn on but then the remote and the touch buttons stop working. Cannot change the volume, change input or anything. I have to turn off cable box putting tv with no signal for 15 minutes before it will turn off,
  • 3 Answers
SOURCE: LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Posted on Jul 30, 2008
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 235 Answers
SOURCE: Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Posted on Jul 05, 2009
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
47" lg 3D tv won't change inputs and only displays "HDMI 3"
Try changing inputs using the touch buttons on the front lower right bezel of the tv.
Feb 12, 2017 | LG Televison & Video
Tv remote wont work even though new batteries are put in.cannot change channels or volume or even turn the tv off or on
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
Feb 17, 2015 | LG RU-42PX10 42 in. HD-Ready Plasma...
Why is my lg 55le5500 display a white screen
possible mainboard or panel issue. does the white screen ahs any letters or just white with no sound etc ??? when you turn it on does the lg logo appears ??
Jul 26, 2014 | LG Televison & Video
Remote will not change channels
If you are using the original remote, it has failed.
Sep 26, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
I can not get the power lights and standby lights to turn off even when i turn them off in the menu , the remote is sluggish, and if i turn tv on on the tv i get a long beep my tv is a 55 inch led lg...
First thing to try would be to update the firmware. This link should take you to the LG support site where you can find the download and instructions you need to update your television. Look under drivers and software. Good luck.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=55LE5500
Apr 28, 2011 | LG 55LE5500 55 in. HDTV LED
Seems like some type of control board problem. Remote will not work on tv, but works other devices. Manual controls are squirelly. Cannot change inputs. Can move to other inputs on menu but when I hit...
Thats a bad button on the front keypad of the tv . The remote does not work because the tv micro sees a button pressed all the time and never listens to the IR reciever . If you pull the front speaker grill off you will find connector ZF just below the keypad or just inside the access panel. If you do remove that panel don't touch anything else.Just follow the wires down from the keypad to connector ZF. Connector ZF is inline with the wires to the front keypad. Unplug it . Then remote will work like normal. Use it like that or have the front keypad buttons replaced.
Oct 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
LG 32LC7D side buttons on tv stopped working
Tries to change to new batteries,same thing after that ur remote IC incoder is damages.Tries this website buy an exact remote or very close to it.1-800-Remotes Factory Original.
Sep 12, 2009 | LG 32LC7D Television
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 55LE5500 55 in. HDTV LED Logo
141 people viewed this question
Computer Repairing
Computer Repairing
