Question about OKI C5100n Laser Printer
Kyocera print on samsung galaxy s3 does not connect to oki c5100n
Althoug listed in the compatibility list, my samsung galaxy s3 does not connect to c5100n. neither using different search protocols nor by adding the ip adress manually.
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Posted on Jan 02, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Posted on Jan 13, 2008
SOURCE: OKI C5100n Laser Printer
My semi-educated guess would be that your transfer belt unit is getting close to the end of it's time - This is Part No. 351002.
Posted on Aug 05, 2008
faxman789
  • 297 Answers
SOURCE: i need linux drivers for OKI C5100n
Some Oki LED printers do have Linux drivers available. You should contact Okidata here:
my.okidata.com
or
1-800-OKI-DATA (1-800-654-3282)
Posted on Jan 22, 2009
  • 97 Answers
SOURCE: Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Posted on Mar 29, 2010
I need help password does not work with samsung s3 , but 0000 if it works with Nokia , why?
The Samsung Galaxy S3 uses Bluetooth 4.0 LE. This power-saving connection feature isn't always backwards compatible with older Bluetooth protocols. Samsung didn't include the backwards compatibility. Your Nokia device is obviously compatible with the EM227's Bluetooth signal.
For some information on the issue, you can read the Wikipedia article here: https://en.wikipedia.org/wiki/Bluetooth_low_energy .
I wish that I had better news for you.
Aug 05, 2015 | Emerson EM227 Bluetooth Headset
My phone is locked. My phone is Samsung galaxy s3
Hi. Do you want to unlock your Samsung Galaxy S3? If so, from what kind of lock do you want to unlock it? If you Samsung Galaxy S3 has been locked up with a network lock, you can unlock it safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
Jul 12, 2014 | Samsung GT-i9300 Galaxy S3 Unlocked GSM...
Bluetooth pairing. Audio works but contacts not transferred to car. Samsung Galaxy S3 says "audio only"
Having same problem. Same galaxy 3 Phone not compatible with my
BMW system bluetooth either.
May 04, 2014 | 2006 BMW 5 Series
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
Youtube example of MHL to TV:
How to Mirror or connect Samsung Galaxy s3 to TV
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
Youtube video:
How To Use Samsung Link previously AllShare Play
Jan 15, 2013 | Samsung Galaxy Cell Phones
Turn on predictive text on a sumsung galaxy S3
click the cog and then it brings up a list of settings including predictive text just slide the slider to ff
Jun 16, 2012 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
Jul 24, 2008 | OKI C5100n Laser Printer
Can't find my printer!
how did u connect the printer, (USB, Paralell, Network), if it is usb and is connected to a pc it must appear, if doesn't u may have a motherboard problem, if it is paralell or network, u must instal the printer as a paralel printer and if it is a network after u install it u must change the port to a IP port.
good luck
Jun 01, 2008 | OKI C5100n Laser Printer
Nov 13, 2007 | OKI C5100n Laser Printer
OKI C5100n Laser Printer Logo
107 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
